Afternoon Bongo peeps.
I have a problem with the ignition key not being released when parking up. I can see the issue is the release cable under gear lever and a bit of a push releases the catch and key can be removed. It's been like this for a while but having recently parked my Smart car in a ditch I have to use the bongo more often for little trips and it is beginning to niggle me. Question is this a known problem and if yes where is the sticking taking place, what has to come out to access it etc?
Any pics?
ignition key stuck.
Re: ignition key stuck.
Here is the diagram, thought there was an adjuster at the ends to get the tension/length right, but is could be a snapped wire in the Bowden cable catching as well of course ? http://www.lushprojects.com/bongopartsm ... o=.html#11
Thanks again Geoff!
