Auto gearbox stuck in lower gears
Posted: Wed Sep 02, 2020 12:57 pm
by JimLad
Hi Bongo people, I wonder if you can help me...
I have a 2.5TD Auto from 1997 and I'm having a problem with the auto gear box.
Basically the gears are sticking as I get to 2nd or 3rd, and also randomly change down to 2nd sometimes when I pick up speed on perfectly flat roads.
It seems to only happen for the first 10 minutes or so of driving, and I'm forced to use the 'Hold' function to force it into 3rd once I pick up speed. After a while it seems to fix itself. (I am using 'D' by the way)
I've checked the transmission fluid and it's full and clear pink. I will probably end up taking it to a garage, I just wanted to know what you guys think.
Thanks!
Re: Auto gearbox stuck in lower gears
Posted: Wed Sep 02, 2020 2:26 pm
by Bob
Hi, and welcome aboard.
Don't want to teach you to suck eggs, but did you check the fluid level with it hot, and with the engine running, after cycling the selector a few times?
Posted: Wed Sep 02, 2020 10:22 pm
by JimLad
No no, please teach!
I know nothing about these things.
I tried when it was still warm and running, maybe I'll leave it on for longer and move the selector before trying it again. (you mean the gear selector right?)
Thank you for your reply.
Posted: Wed Sep 02, 2020 10:25 pm
by Bob
Yes.
Engine up to full temp, park on level ground, cycle gear selector (gently) a few times, then remove dip stick with engine still running.
It can be tricky to spot the level.
Posted: Wed Sep 02, 2020 10:41 pm
by Ian
Also sniff the ATF. If it smells like burnt toast it needs replacing.
Here's some other things to check (copied from the "Juddering" fact sheet in the members area of main website)
Not all gearbox problems are actually gearbox problems at all. Lots of things affect when the gearbox changes, including the fuel filter, banjo filter (top of the fuel pump), throttle position sensor, and turbo pipework leaks. All these can fool the gearbox into conflict.
Assuming it’s none of the above, then look at these queries from the Bongo Fury Forum.
“In the last couple of days, my auto-gearbox seems to have developed problems, especially between first and second gear. Sometimes I get a judder when pulling away from a standing start; at other times when I am in slow moving traffic and go to speed up the engine revs too high. On other occasions when it attempts to change between first and second it takes a few seconds and then changes with a big jolt. Any clues?”
This sounds like the forward clutch is starting to slip.
“I have a 2002 bongo with 85,000 miles on it. Standard 2.5d. I’ve just replaced the transmission fluid pipes on my Bongo after a fluid leak at a garage here in Brecon. As a result of the leak I had no gear engagement at all but did manage to crawl 150m to park up before arranging recovery. After being fixed, when I’m travelling at a very slow speed turning left or right, or starting off (not all the time), first gear does not engage straight away and I get a judder when it does. What do you reckon?”
Assuming your oil level is correct, you may have damaged your forward clutch by driving it slipping. It only takes a few yards to total a slipping auto clutch. I take it the judder isn't a Limited Slip Differential (LSD) judder from the rear axle when cornering?
Posted: Thu Sep 03, 2020 2:27 pm
by JimLad
Thanks for your replies, really good info there.
I have a hunch it may be the throttle sensor.
The gear changes themselves sound fine, it just takes way more speed sometimes to get it to change up.
I've only had the van since March, and it only started doing this recently.
The only thing I've changed on it is the speedo.
Posted: Thu Sep 03, 2020 3:00 pm
When you say you changed the Speedo what exactly did you change ?
There are 6 outputs from the speedo to all sorts of things including the ECU and hence the gearbox, see top and left of the diagram;
Posted: Tue Oct 20, 2020 4:10 pm
by JimLad
Just the faceplate to one that reads in mph. Although I had to take a lot of it apart to get to it, I'm pretty certain that I put everything back together as it was.
(Sorry for the delayed reply)
Posted: Mon Nov 08, 2021 7:08 pm
by tuvster
JimLad wrote: Wed Sep 02, 2020 12:57 pm
Thanks!
Hi just started developing an issue with my freda , had a new fuel pump fitted , got it back and the gears seem strange now , going from 2nd to 4th pretty much missing out 3rd , having to use hold more than i ever have , wondered if anyone can help? the fluid is new by the way
EDIT
Duplicate post here
viewtopic.php?f=3&t=78151&p=720765#p720760
Posted: Thu Nov 11, 2021 10:43 am
by JimLad
tuvster wrote: Mon Nov 08, 2021 7:08 pm
My problem seemed to just fix itself after it's last service.
Mechanic said the fluid was fine but I got him to change it anyway. Only other thing of note was that my radiator was massively blocked with leaves, so I cleared that off. It was still playing up for a week or so and then never happened again.
I don't know if we had the same problem, my gears were also jumping down at random times. Like the engine was struggling for some reason and just telling the gearbox it needed more revs.
That's my story anyway, hopefully one of the experts on here will be able to give you more insight.
Posted: Fri Nov 12, 2021 7:52 pm
by tuvster
Thanks jim
Posted: Tue Nov 16, 2021 11:54 am
by oibaf
I don't have much to add but, did the Hood light flash on the dash? Did you read the codes if so?
There's a handy guide to that here
http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
