Suspension mounting
Posted: Thu Aug 27, 2020 9:44 am
Hi there, my van has recently failed our MOT equivalent with the same problem being identified on all four corners "A damaged, cracked, fractured, worn or exhausted spring component" on the "spring (coil/leaf), stabiliser and torsion bar".
Speaking with the tester and the terminology he used was it was the mounting platform that the coil springs sit into that have corroded and need replacing. Has anyone experienced this or know how to go about addressing it?
Looking at parts diagrams online, the rear coil spring seems to sit into a link/bar and the front appears to sit into part of the actual damper. From talking to the tester it was metal parts he was referring to so not any rubber seats or bushings or anything.
Appreciate any advice / opinion or even the terminology for what I'm looking to replace.
Many thanks
Many thanks
