Rear top fans not blowing
Posted: Sat Jul 11, 2020 5:57 pm
Hi all
We have a 97 bongo with the electronic air con.
We've set the rear fans to blow (hold down the Rear button and then set the air direction to the top and increase fan power) but nothing comes out of the rear air vents. If you listen carefully, I'm sure that it's possible to hear some kind of servo power up behind the offside panel behind the drivers seat, where the vertical air ducting is that feeds the top vents. But no actual air flow.
Is there some way I can diagnose this? Are those fans powered by a fuse that I can check, or are there some cables I can do some volt tests on?
Any advice welcome.
Olly
Any advice welcome.
Olly
