Issue with Bongo, mechanic needs part. Not sure what it is! Temp sensor?
Posted: Fri Jan 10, 2020 5:29 pm
Hey all!
Had some issues with my V6 van. Was working perfectly and then couldnt get it started correctly when I woke in the morning.
It would start and then continuly cut out unless throttle was given. Also an extreme lack of power and possible misfire/rattling on the 70 mile journey back at 40mph.
My mechanic started with replacing things like HT leads, distibutor cap, rotor arm and the likes. Seems it still has a problem.
He has asked for a part I've posted below. I can only seem to find an aftermarket one. He says its an engine temp sensor but I'd imagine those are tiny. This appears to be a 'Fuel injection idle air control valve (https://www.carid.com/standard/intermot ... ac260.html).
Has anyone had similar issues? Ive sent him info on diags using the flashing light..etc.
Is this the correct part for V6 petrol bongo? Should I suggest somthing else?
Thanks very much, any help would be appreciated.
His original message below:
https://i.ibb.co/Q8Ypst7/bongo.jpg
Regards
Regards
