Heater takes a while to produce warm air
Posted: Wed Nov 20, 2019 5:51 pm
by junglist
Hello there,
My Bongo's heater takes quite a while to produce anything like warm air. I would say about 15 to 20 minutes.
Watching the 'Bongo bleed' videos mentions the heater matrix having air pockets possibly. The coolant was replaced a year or so ago but shows no sign of being low (I have a coolant alarm and check levels regularly).
Would air pockets not work their way out over time or is this likely the problem, even though the level hasn't changed?
Thanks!
Re: Heater takes a while to produce warm air
Posted: Wed Nov 20, 2019 6:36 pm
It could be blocked with disturbed gunge from the coolant system, on the otherhand most of the Bongo's take a good 10 minutes to warm up.
Posted: Wed Nov 20, 2019 6:57 pm
by Bob
I'm with Geoff.
The diesels do take a good while to get warm.
Posted: Thu Nov 21, 2019 9:44 am
by Flanners
The 2.0 gets up to temp and supplying warm air very quickly.
Posted: Thu Nov 21, 2019 11:17 am
by junglist
I'm running a diesel and timing it properly, it does indeed take about 10 minutes to warm up. Good to know that's expected and nothing is wrong.
Thanks all for your replies.
Posted: Sat Nov 23, 2019 6:44 pm
junglist wrote: Wed Nov 20, 2019 5:51 pm
Hello there,
Thanks!
That sounds a bit long to me. One obvious possibility is a tired thermostat thats not closing properly. Do you know how old it is?
