Reading fault codes (flashing light)
Posted: Fri Sep 20, 2019 3:28 pm
by Gripped
Hi All
Decided to health check the V6 Bongo, and managed to get the diagnostic set up with the flashing LED and jumper wire.
If I posted a link to a video of the flashes, would anyone be able to read what the codes mean (i.e. bongo morse code)
I'm strugging with the sequence of flashes.
Any help much appreciated.
Re: Reading fault codes (flashing light)
Posted: Fri Sep 20, 2019 5:13 pm
Some of the later ECU's use a 4 digit code not just 2 digits that came out on the earlier versions.
Posted: Sat Sep 21, 2019 9:55 pm
by Gripped
Ours is a 2001 so does that help at all?
Posted: Sun Sep 22, 2019 9:02 am
Posted: Sun Sep 22, 2019 8:59 pm
by Gripped
Brilliant thanks.
So. After some Bletchley Park style decoding, here are the codes [ L = long flash, S= short flash]
L L S L L = 0100
L L S L S L = 0110
L S L S S S S S L S S L S = 1521
So, possible MAF sensor issues
Intake temperature sensor issue
VRIS solenoid issue.
However, they are all linked (air flow and temperature) so could just be one sensor. I'm planning to replace the intake temperature sensor (cheapest) and then solenoid if needed, and finally the MAF if needed.... as the MAF is expensive !!
Posted: Mon Sep 23, 2019 8:02 am
by Katka
There are many MAF Cleaners available, for £5 - £10. They seem to have very good results for users and might be worth a go before buying a new MAF. The nearest experience I've had was using contact cleaner on the switches for Bongo blinds and it worked a treat. Saved replacing them.
