Diffs/transfer box/lsd
Timandclaire
Post by Timandclaire » Mon Sep 02, 2019 1:43 pm
Do they all use the same fluid?
I'm assuming that i don't have lsd as i can't find a yellow sticker due to excessive underseal being applied! Is there another method of identification?
Bongolia
Re: Diffs/transfer box/lsd
Post by Bongolia » Mon Sep 02, 2019 2:49 pm
Is it 4wd?
Bongolia
Post by Bongolia » Mon Sep 02, 2019 2:50 pm
Likely a different oil if lsd.
Timandclaire
Post by Timandclaire » Mon Sep 02, 2019 3:42 pm
Yes it is 4wd ..
Post by Northern Bongolow » Mon Sep 02, 2019 7:56 pm
Jack the rear up, both rears, slowly turn one wheel, if it's ltd slip the opposing rear wheel will slowly turn the same way, if it's not ltd slip it will make the opposing wheel rotate the opposite way.
Timandclaire
Post by Timandclaire » Mon Sep 02, 2019 10:35 pm
Thanks for that👍
Post by Northern Bongolow » Tue Sep 03, 2019 12:31 am
With it being 4wd turn it with force to the point before the the 4wd viscous coupling starts to grip, too little force may not be detected on the rear axle LSD, you will get the feel for it.🤔
