Side door stuck closed- mechanism working.
Posted: Sat Aug 10, 2019 3:07 pm
Hello all, again.
It seems my Bongo has to have at least one fault. It seems to be starting again now, which is a relief, but after a heavy downpour the other night, with the window slightly open, the side door will not open. It is not the child lock as it doesn't open from the outside either.
I have searched the forum and tried all of the suggestions but I'm stuck. I can't get the door handle off - have tried removing the horseshoe clip and after an hour have given up - impossible. so, I'm pulling the panel back and trying to poke around in the mechanism to the rear of the door. All the rods and rockers seem to do what they need to do. When the door closed, the occupant said that the auto-close mechanism kicked in without warning, so maybe this is locked on?
I can see the microswitch and it is in the closed position, but I can't open it as the white plastic cam above it is locking it in place. I have disconnected the battery, reconnected, worked the lock, hit it, kicked it and sworn a lot but it still won't budge.
Any ideas?
Many thanks,
Sam
Any ideas?
Many thanks,
Sam
