Temperature gauge not moving….
Posted: Mon Jul 29, 2019 11:42 am
Hello all,
just a quick question….
yesterday had a coolant hose split. No big drama, as low coolant alarm sounded,and I was able to switch off immediately.
Recovered home, and Ive replaced the split hose and bled the system using the see-saw method.
All is well. Front and rear heaters hot, bottom hose is hot.
But temp gauge is not moving. Except the tiniest movement downward when I switch on the ignition.
Ive earthed the single wire feed to the sensor….no movement from the gauge.
I'm guessing that by bizarre coincidence the gauge has died?
Any ideas welcome!!
Russ
Any ideas welcome!!
Russ
