Atf fluid removal
Timandclaire
Atf fluid removal
Post by Timandclaire » Sat Jul 27, 2019 1:30 pm
I intend to change my atf fluid and would like to do a thorough job
My question is what is the best method to ensure i get all of the fluid out specifically from the torque converter?
I understand i can pump fluid out via the dip stick and drop the sump ..however i'm unsure if doing it this way would clear the torque converter.
Many thanks Tim
Re: Atf fluid removal
Post by g8dhe » Sat Jul 27, 2019 3:29 pm
Not sure you ever can drain it completely see viewtopic.php?p=683745#p683745
Roy748
Post by Roy748 » Sun Jul 28, 2019 1:33 pm
Hello.
I drained mine, well as best I could through removal of the sump, therefore allowing me to clean the filter too. I refilled it with around 4 litre. I appreciate I could not fully drain it all, but after 200 miles drained it again only this time using a electric pump via the filler tube, topping up with just over 3 litres. The combined efforts have gone a long way to changing most of the aft oil.
Hope that helps.
