"Fridge" dilemma in unconverted bongo
Treetalk
Post by Treetalk » Mon Jul 22, 2019 1:42 pm
I got some great ideas and help at annual Meetup in June re. my newly purchased unconverted bongo, which was v helpful. But one issue remains - how to keep stuff cold.
I didn't really fancy buying a £500 fridge to keep a pint of milk and some bacon cold! OTOH, the camping "ice packs" of old, though practical up to a point, seem a little Stone Age and of course require a campsite to freeze.
I do have a leisure battery, but am I right in thinking that this is not generally powerful enough to run an electric coolbox? Am I right in thinking I could buy a portable solar panel to assist in this? Finally are electric coolboxes noisy - I definitely would not want to run at night if so.
All and any illuminations or ruminations on this subject gratefully received, even if it just leaves me where I started with my ice packs ...
Roy748
Re: "Fridge" dilemma in unconverted bongo
Post by Roy748 » Mon Jul 22, 2019 2:21 pm
Hello and welcome aboard.
We have also wrestled this dilemma and have found what we consider a good solution. We bought a Aldi cool box that runs on both 12v or 240v its 29 litres I believe. which is a good size. When electric is available we use that to run it and when not we have a 60w portable solar panel connected to the leisure battery which appears to cope well. Advantage of it being portable is we can follow the sun around maximising its effectiveness. For short weekend breaks I bought a waeco coolbox which sit in the middle of the seats, type of armrest. Which again works well but is only 12v, but being smaller pulls less from the battery.
Post by Bob » Mon Jul 22, 2019 4:36 pm
If you keep a couple of chill blocks in the type of chiller described above they should keep things cool enough overnight even if you turn it off to preserve 'The sound of silence'. :wink:
john14.6
Post by john14.6 » Mon Jul 22, 2019 6:32 pm
We have the same coolbox from aldi, solar or electric is a must when running it, we run ours off 220w solar, panels the noise is easy to forget [like your laptop or pc], the fan noise just blends in, we could not live with out ours, having a 4 month and 2 year old plus keeps my insulin cold
When we used the car for our trips ice block bags were the only way,
Treetalk
Post by Treetalk » Tue Jul 23, 2019 10:22 pm
Thanks, that all makes sense.
The Aldi one is sold out online, of course!
But at least I know this is probably the direction I need to go in in the future....
Post by Bob » Tue Jul 23, 2019 11:18 pm
This looks handy:
https://www.amazon.co.uk/Andes-Insulate ... 3507&psc=1
Chill on mains overnight before you leave, add a couple of chill blocks from the freezer, run on 12v while driving, solar panel/leisure battery on site, switch off overnight... job done. 8)
Feeline
Post by Feeline » Wed Jul 24, 2019 7:57 pm
Sorry to jup in on your thread.
We REALLY need a fridge as a lot of the camping we do means we have no access to electricity or shops for up to 6 days.
I was looking at a compressor fridge with a combination of Leisure battery and Solar panels to power it.
Is this even feasable?
(All we have at the moment is a coolbox)
Post by Bob » Wed Jul 24, 2019 8:14 pm
Welcome aboard. 8)
Pretty sure it is possible, have a go with the 'Search' box, top right.
Put 'and' between words to improve results, eg 'Fridge and leisure and battery'.
Try a few combinations as there's been a lot on this subject in the past. :wink:
Post by g8dhe » Wed Jul 24, 2019 9:29 pm
Yes quite feasible, a 100AmpHr+ LB, Split Charge Relay (to allow charging when driving), 100W Solar Panel and Controller will keep you running 24/7 with a 42l compressor fridge and normal use of lights and radio etc. no problem.
Post by mikeonb4c » Thu Jul 25, 2019 8:16 am
g8dhe wrote: Wed Jul 24, 2019 9:29 pm Yes quite feasible, a 100AmpHr+ LB, Split Charge Relay (to allow charging when driving), 100W Solar Panel and Controller will keep you running 24/7 with a 42l compressor fridge and normal use of lights and radio etc. no problem.
2nd that. Yes it was indulgent on the £s but my Waeco 18 litre coolbox and 100w solar panel combo takes care of business perfectly for my regular no hookup camping needs. For me its been worth every penny,
Treetalk
Post by Treetalk » Thu Jul 25, 2019 2:45 pm
All the extra posts were helpful :)
Post by Bob » Thu Jul 25, 2019 3:07 pm
Start us chatting... :lol:
bongotoffee
Post by bongotoffee » Thu Jul 25, 2019 5:13 pm
I have just got my leisure battery wired up and we are hoping to run the 12V coolbox on it. I think we will run it in the day only and hope for the best!
Will let you know ...
Post by Bob » Thu Jul 25, 2019 5:30 pm
As suggested I'd pop a couple of chill blocks in it.
Temp will drop at night and you won't be opening it so I recon you'll be fine. :wink:
Jillygumbo
Post by Jillygumbo » Fri Jul 26, 2019 10:43 am
I don't run my fridge at night if I don't have ehu, which is most of the time. I have a 'freezer' part at the top and keep a flexible thing in it permanently - keeps things colder and is available for emergencies.
Jillygumbo, Marvin & Lady
