Re: Issues since being laid-up
Posted: Mon Sep 20, 2021 7:00 pm
Thanks for the heads-up on this, I wasn't aware that it existed.Northern Bongolow wrote: ↑Mon Sep 20, 2021 6:09 pm There is a filter inside the fuel tank, it's on the end of the pickup pipe only accessable if you take the top of the fuel tank.
Instead just blow back to the tank from the fuel filter to clear it.
I did this today, I used a tyre inflation compressor to blow pressure down the tube. It was gurgling in the tank so I guess it confirms that the pipe & tank filter isn't blocked. When I removed the tube off the filter I expected diesel to pour out, but it didn't, is that correct?
Im assuming the fuel pump is mechanical, and not an electrical one at the tank?
Next step is the banjo screw filter, I'll need to get a socket set to get to to it. It looks to be 14mm?
If that filter is clear, then I'm at a loss
