"Pinking" on my 2.0lt petrol bongo
Posted: Mon Apr 15, 2019 1:55 pm
by Roy748
Hi all
Just wondering if any other owners are experiencing the same engine pinking sound at 1500 rpm. I think it's called pinking, it only happens at low revs and when under load, or mainly when the engine is cold. I have tried filling at different fuel stations and some seem to help. Any ideas as to what it is and how it could be resolved.
Thanks in advance
Re: "Pinking" on my 2.0lt petrol bongo
Posted: Mon Apr 15, 2019 4:45 pm
by Flanners
Plugs new-ish and correct? are you using supermarket petrol (I've stopped using it)? How about some Millers/octane booster or Redex on the next fill?
Posted: Mon Apr 15, 2019 5:07 pm
by Roy748
Hello.
Plugs I believe are ok as runs very smooth with a good tick over. I believe it's most prevalent after using supermarket fuel, and having read a few threads on here it would seem it's a common problem.
Posted: Mon Apr 15, 2019 5:11 pm
by ognob
I’d try the other fuel or additives as suggested
Worth it for science
Posted: Mon Apr 15, 2019 5:19 pm
by Roy748
Thanks, will do.
Posted: Mon Apr 15, 2019 6:28 pm
by teenmal
Ha ha, pinking, some of my old customers used to call it jingle bells. (Pre ignition).
Take care.
Posted: Mon Apr 15, 2019 6:59 pm
by TheLongRoad
Run mine on the cheap supermarket stuff and it doesn’t ‘pink’. I love that term, to pink, my Dad used it a lot as his Ford Anglia did it all the time
Posted: Tue Apr 16, 2019 7:31 am
by Bonneville
Check your ignition timing. It's in the service book but in Japanese so I can't tell at what mileage. Unlike modern cars, no knock sensor or stick coils on Bongo so there is no way to compensate for wear or fuel quality. I suspect it's never checked over here hence folk having issues as they get older. Mine was a degree out. Needs to be 6 degrees BTDC.
Posted: Tue Apr 16, 2019 7:49 am
by Flanners
Posted: Tue Apr 16, 2019 11:20 pm
by Roy748
Thanks for all the helpful advice, definitely some good pointers to consider.
Posted: Wed Apr 17, 2019 6:55 pm
by BongoBongo123
Regarding supermarket petrol. The one time I put it in a petrol car did nothing to persuade me me that the reports
of cars not running well on it were untrue. I had Millers Eco Max in there as well so it probably would have ran like
a bag of spanners if I did not have that in. It seemed to lack poke and refinement compared to standard BP which I normally
put in.
I was under the impression that pinking (like a ticking/rattle-y noise) when accelerating was a symptom of timing or fuel mixture running lean.
Worth doing the easy bits first, maybe change your air filter (which will do no harm in itself).
