Exhaust manifold EGR pipe blank
Posted: Tue Mar 12, 2019 9:52 pm
by St3f4n
Good evening all
Im wanting to remove the EGR on my 2.5 Bongo.
Done plenty of searching and can see the blank plate for the inlet side is readily available, but I'm wanting to remove the pipe at the exhaust side, I've seen posts saying you can blank it with a plumbing blank? Does anybody know the size needed to save me going into screwfix with an exhaust manifold
Thanks in advance
Re: Exhaust manifold EGR pipe blank
Posted: Tue Mar 12, 2019 10:23 pm
by Bob
Pretty sure they were available from Allan's, Plymouth, but the law has changed on doing such things.
And welcome aboard.
Posted: Wed Mar 13, 2019 1:09 am
by Northern Bongolow
Don't remove the fitting in the rear of the manifold it's a real oddball size and thread, cut the pipe to it and go for a normal external compression fitting and olive, if I remember right it's just a standard 22mm blanking fitting mine survived for years without problems.
Just a word of caution, the egr unit has a position sensor on the top, this sends a signal to the ECU and vice versa to confirm it's open closed when needed, no signal may give dash warning light.
Leave the wiring in place, and the unit, just blank off the pipework. It also isnt possible to confirm if it's removed blamked off should you have trouble at mot time in the future.
Posted: Wed Mar 13, 2019 10:24 am
by teenmal
Why do you want to blank (Disable ) the EGR system ?
It is actually Illegal to do so .
Posted: Wed Mar 13, 2019 3:51 pm
by St3f4n
Bob wrote: Tue Mar 12, 2019 10:23 pm
And welcome aboard.
I did check the link to Allan’s but have seen they no longer list them since the changes last year
Thanks for the welcome
Northern Bongolow wrote: Wed Mar 13, 2019 1:09 am
Top job, thanks, hadn’t thought of going down that route but that sounds like it’ll do the job
Posted: Thu Mar 21, 2019 5:37 pm
by nth
teenmal wrote: Wed Mar 13, 2019 10:24 am
Well the biggest advantages would be to stop the engine being deliberately strangled & also stop the inlet track being clogged up with exhaust soot.
Posted: Thu Mar 21, 2019 8:48 pm
by teenmal
nth wrote: Thu Mar 21, 2019 5:37 pm
When is the last time you De clogged the Inlet Track ? and would you just blank off a leave it.
Take care.
Posted: Thu Mar 21, 2019 10:07 pm
by nth
I've never done it on my bongo, but done it on plenty of other cars. I went to blank off the bongo EGR valve as soon as I got it but someone had beaten me to it.
I have seen ports on inlet manifolds more than half in diameter. The last one I done I scraped the worst of it off with a screwdriver then had to leave the manifold soaking in petrol overnight before steam cleaning it.
Yes I would leave the EGR system permanently blanked off.
check out some of these >
https://www.google.co.uk/search?hl=en&t ... h2ZZMxysTE
Posted: Fri Mar 22, 2019 8:54 am
by teenmal
nth wrote: Thu Mar 21, 2019 10:07 pm
nth,this was meant for the OP
"Why do you want to blank (Disable ) the EGR system ?
It is actually Illegal to do so "
I see where you are coming from regarding the IM images , but this is purely down to very poor maintenance (PM) of the vehicle.
I feel very strongly about protecting our future generation .
Take Care.
Posted: Fri Mar 22, 2019 10:13 am
Interesting refreshing my memory on EGR- it reduces NOx emissions but increases particulate emissions. Both are bad for health and the environment: the jury seems to be out on which is worse. I'd say the biggest contribution Bongo drivers can make to public health and the environment is don't drive when you can walk, lower our mileage, and stay out of congested traffic in populated areas where possible (and taxes and levies are encouraging us on that). I wouldnt think removing the EGR is that irresponsible (though i think its now an MOT failure?). I still have my EGR fitted - my inlet manifold has never been maintained. Is that bad?
Posted: Fri Mar 22, 2019 11:08 am
by teenmal
mikeonb4c wrote: Fri Mar 22, 2019 10:13 am
Its very bad,especialy if Adrian did not do it when he change the cylinder head on your vehicle
Posted: Fri Mar 22, 2019 1:07 pm
Good point -can't rule that out. Adrian is very good at keeping costs to customers down where he doesnt think work is necessary (he's even talked me out of things i was going to have done for that reason). I trust him absolutely. If cleaning it was important, I'm sure he'll have done it. All i know is my Bongo runs as good as ever. So, to revisit the question, is it very bad maintenance to leave the manifold alone rather than impose a cost on the customer to remove it and clean it. I've never heard of anyone finding the inlet manifold had caused their Bongo engine to malfunction but i'm not a pro like you.
Posted: Fri Mar 22, 2019 4:50 pm
by teenmal
Posted: Fri Mar 22, 2019 5:06 pm
by teenmal
Mikey,you have probably read this before but worth another look, this guy knows what he is talking about.
viewtopic.php?f=12&t=74614&p=700595&hil ... ld#p700595
Posted: Sat Mar 23, 2019 12:02 am
I remember reading this post. We did stuff like this (gas flow tweaking) to our machines when i was young, cos you do. Great stuff if you're into DIYing it and trying to squeeze any small improvement from the Ranger lump, but imho probably most interesting when race tuning etc. But can you imagine what garage costs would be if you asked a pro to do all that. Ye Gods i only paid £3.7k for the Bongo. And anyway, if i race tuned it it would just fall over on the first bend with all that weight up top.
Nope, i think i'll leave the inlet manifold alone until/unless there is a major issue.
