Coolant alarm
Peeweeboy
Coolant alarm
Post by Peeweeboy » Thu Feb 28, 2019 4:35 pm
Hi all just woundering is it normal for the beeper to go off when cornering ? ( not all the time)Checked level and all good thanks lee
Re: Coolant alarm
Post by g8dhe » Thu Feb 28, 2019 5:09 pm
If it really is only when cornering then it sounds like the screw is being exposed as the coolant moves to one side .... what speed are you cornering at ? :D :D
Peeweeboy
Re: Coolant alarm
Post by Peeweeboy » Thu Feb 28, 2019 5:15 pm
:shock: prob to fast then thanks
Re: Coolant alarm
Post by haydn callow » Fri Mar 01, 2019 4:50 pm
Assuming you have one of our alarms. Put a cup of water in and report back.....you must be going fast round long bends....there is a built in delay in the alarm for just that eventuality... but the tank has loads of baffles in it so shouldn’t really happen. If you do have one off eBay then the lack of a delay could be a problem.
