More alternator problems - suggestions for mechanic?
Posted: Thu Dec 27, 2018 1:50 pm
Hi everyone
Just a quick update on things so far.
1. my original alternator died due to a failing regulator
2. fitted brand new one and 400 miles later the regulator died, sent it back for replacement
3. fitted 2nd hand alternator, worked for 400 miles and then died
4. had to get a new alternator fitted in Devon due to the 3rd alternator failing, drove home to Suffolk and a day later it has died.
I have found that the last alternator (new one) was really hot and overheating, I suspect that was the reason all the other failed, what suggestions do you have as to why the alternators would be overheating?
The Bongo is off to my mechanic (mazda trained) next week for him to investigate, but if anyone has any suggestions on where to start looking it might be helpful.
All the alternators worked for 400 miles, putting out about 14.2 volts, then they all stop charging, presumably due to overheating.
Thanks in advance.
James
Thanks in advance.
James
