Electrical problems... please help, its my birthday!
Posted: Fri Nov 30, 2018 5:55 pm
Hi All
I had problems with the charge and sediment light on my Bongo and changed the Alternator for a new one, which worked great for a few hundred miles and then the problem reappeared with the new alternator kicking out over 15v. So I sent it back and am awaiting a return. While i was waiting I brought a secondhand alternator to tide me over and fitted it today. However that too is kicking out too high a voltage and the sediment and charge lights are permanently on.
My batteries are both holding 13.5 volts over several days and seem healthy (all cells are showing the same reading on Hydrometer)
Also when I fitted the alternator today only my side lights work and the headlights do not work at all, even on flash - I have checked and changed the under bonnet pink fuse and that did not help. I have since swopped over the relays and there is no difference to the headlights - they are dead. The bulbs are ok and I put in another bulb just to check and all is ok. They were working fine before the alternator swaps...
So either ive had 3 alternators that are all faulty or there is another problem somewhere that the van is causing??
Any suggestions would be appreciated, I just want to be able to use the van, but its been off the road due to these electrical issues more that its been on the road.
Also, fuse 1 to right of Knee is Ok (ive read this can cause sediment/charge issues is gone)
The only other thing I have done is replace the under bonnet fuse board (the one attached to the battery) as the old one was damaged. I am sure I have wired it all back together correctly but can anyone point me to the correct wiring for this? (it has 2 wires on the back and one on the front, the front one is wired to the furthest holder and not to the bolt holding the main fuse in place... this is correct isnt it?)
Any suggestions or things to check tomorrow in day light would be appreciated.
Many Thanks
James
Many Thanks
James
