Upgrade/ Replacement fob/key
smith335
Post by smith335 » Tue Nov 06, 2018 8:40 pm
Thought i would share this with you all, sorry if its been covered before.
I purchased a flip key/fob from ebay to upgrade/replace my old remote.
and it works a treat, got the blade cut at my local lock smiths and programmed the fob as per the instructions i found on here.
well chuffed, item number on ebay was 253785488649
hope this helps some one.
cheers
Az
2004, 2.0L Aero City Runner
Flanners
Re: Upgrade/ Replacement fob/key
Post by Flanners » Wed Nov 07, 2018 11:41 am
Can you share the link to the post re programming the fob. Ta
smith335
Post by smith335 » Wed Nov 07, 2018 5:31 pm
Not 100% it was on here now i think about it......
here is what i did....
If you change the battery in the remote central locking fob, you'll need this procedure to re-code the fob.
You can also use this for coding spare or new fobs.
1. All doors closed, but unlocked.
2. Open drivers door, leave it open.
3. Put key in ignition, and turn it between ON and LOCK 3 times.
4. Remove key from ignition.
5. Press the drivers door switch 3 times (the switch that operates the courtesy light).
6. The doors should lock and unlock.
7. Press any button on the remote twice.
8. The doors should lock then unlock again.
hope this helps
Flanners
Post by Flanners » Wed Nov 07, 2018 8:34 pm
Nice one thank you, I fancy purchasing a spare fob.
smith335
Post by smith335 » Wed Nov 07, 2018 10:14 pm
glad to help....
ognob
Post by ognob » Wed Jan 16, 2019 2:00 pm
smith335 wrote: Wed Nov 07, 2018 5:31 pm Not 100% it was on here now i think about it......
hope this helps
Step 5 - where is this switch, I’m probably having a blonde moment. Is it the door lock nob up by the window?
Post by g8dhe » Wed Jan 16, 2019 3:28 pm
Open drivers door look at the lower left corner of the door frame you will see the rubber covered push switch, the door pushes it in when it closes.
Post by mikeonb4c » Wed Jan 16, 2019 5:14 pm
g8dhe wrote: Wed Jan 16, 2019 3:28 pm Open drivers door look at the lower left corner of the door frame you will see the rubber covered push switch, the door pushes it in when it closes.
Geoff - Surprised to read above that this switch is more than just a simple/dumb switch Geoff. Could it really be used as part of reprogramming a key fob on my ancient 1995 Bongo? I don't actually have a remote fob, but if I did...... :roll:
Post by g8dhe » Wed Jan 16, 2019 5:55 pm
Its is just a dumb switch, the immobilsers and remotes watch the 12 volt supply rail for the lights and other sensors and watch for a "pulsed" voltage drop to occur, quite often the cause of oddities if other things are operating at the same time ;-)
Post by mikeonb4c » Wed Jan 16, 2019 11:31 pm
g8dhe wrote: Wed Jan 16, 2019 5:55 pm Its is just a dumb switch, the immobilsers and remotes watch the 12 volt supply rail for the lights and other sensors and watch for a "pulsed" voltage drop to occur, quite often the cause of oddities if other things are operating at the same time ;-)
Thanks as ever Geoff and ye gods what a strange concept! If I fit a 2000ah battery will the voltage drop be too small to trigger it? :roll: :lol:
Post by g8dhe » Thu Jan 17, 2019 10:12 am
No the voltage will still vary sufficiently.
Post by mikeonb4c » Thu Jan 17, 2019 10:54 pm
g8dhe wrote: Thu Jan 17, 2019 10:12 am No the voltage will still vary sufficiently.
Good to know Geoff!
ognob
Post by ognob » Fri Jan 18, 2019 12:21 am
Thankyou all
Once I sort out the bigger jobs, I shall be into a new second key fob, cheers
ognob
Post by ognob » Wed Feb 27, 2019 9:31 pm
This video looks very similar
https://m.youtube.com/watch?v=mShU9jRAsIU
Watch it whilst read8ng the above instructions
ognob
Post by ognob » Wed Mar 27, 2019 11:03 pm
Followed the instructions in the video using the key mentioned above and it worked!
I now need to get the blade cut
