Drive Belts - 2.5 Diesel
Posted: Mon Sep 17, 2018 5:55 pm
Hi all
After some advice. I have a 2.5 Diesel that developed a little bit of a squeak at tick over that I was sure was from one of the belts. Probably the Air con as it got worse when switched on.
Plus to my knowledge they have never been changed or at least not for a long time so thought it was worth changing them anyway.
So I bought some form one of the normal on line suppliers but when they arrived they were not exactly the same. they were the toothed type V belt rather than smooth. I don't actually think that makes any difference so wasn't too worried.
When fitted I am sure that they were not exactly the same length either.
So I fitted them anyway and at first start up all good. Sounded much better, quieter than it had been for a while so was defiantly the problem.
Took it for a run but now at 2000rpm or over i get a whine so wondered if it was too tight so loosened them a bit and it helped a bit but not fully.
Seems to be coming from the alternator belts as Aircon on or off makes no difference. so could be alternator or water pump i guess.
Thought they may bed in a bit in so didn't worry too much but when I started up again a week later it was squeaking again (but worse) and whining even worse. the squeaking does stop once warm though
So Finally my questions. lol
Does this sound like its just an issue with the belts or have I now unearthed something else like water pump.
I wasn't over happy with the quality of the belts but that may have been me being picky.
Has anyone else ever had any issues with changing belts. Does quality cause issues.
They were not from our shop by the way.
