Fuel gauge
Posted: Tue Oct 31, 2006 10:47 am
by Mikey B
Just noticed this yesterday, the fuel guage was still reading with the keys removed from the ignition. I only noticed it because I was using a battery charger because the battery was flat. Don't know if the charger caused the needle to rise while I was charging the battery.
Any ideas?
Posted: Tue Oct 31, 2006 10:52 am
by pippin
There has been discussion on this before and the consensus was that the fuel gauge/guage for some odd reason does continue to read for a very long time (if not permanently) after the ignition is turned off. Weird/wierd.
fuel guage
Posted: Tue Oct 31, 2006 11:21 am
by Mikey B
pippin wrote:There has been discussion on this before and the consensus was that the fuel gauge/guage for some odd reason does continue to read for a very long time (if not permanently) after the ignition is turned off. Weird/wierd.
If on permanently, would this cause the battery to drain? Just wondering incase I need to get a new battery, as I didn't use the Bongo from Saturday afternoon until monday morning, when I did flat battery.
Posted: Tue Oct 31, 2006 12:20 pm
by pippin
Cannot answer that one directly except to say that we have never had a flat battery in our Bongo.
Posted: Tue Oct 31, 2006 1:13 pm
by Veg_Ian
The fuel gauge type where the needle continues to read without a power source is common across most Japanese vehicles. It doesn't drain your battery as it relies on a heavy damping mechanism to work.
Posted: Wed Nov 01, 2006 3:55 pm
by Glynanderson
I've heard this 'heavy damping' theory before, I'm sure it's right but...
if it's so heavily damped, would it ever move????
Just a thought
Posted: Wed Nov 01, 2006 4:07 pm
by alant54
Yes it does move....mine moves rather quickly from full to 1/4 after 300 miles......rather slow going the other way when filling up....
...Alan
Posted: Thu Nov 02, 2006 10:13 am
by Kentish Paul
Mickey B: Just to confirm that the fuel guage is displaying the level all the time and uses no electrical power. And yes, after filling up it can take a full five minutes to confirm that you did not just half fill the tank.
I have found my Bongo's battery very resilient. In the winter, I often do not use the Bongo for more than a month at a time. On the coldest morning it fires up clan as a whistle. Earlier this year, I was told by a neighbour that I had gone on holiday with one of the interior lights switched on (two weeks). No problem.
So I think you may have to look elsewhere for what is draining the battery. Lots of threads on that here.
