Help with Diagnostic codes
WebWiz
Post by WebWiz » Thu Jul 05, 2018 11:10 pm
Hi guys,
I need some help with these fault codes as bit confused. I jumped gnd and tat to give me transmission codes but got allsorts flashing on hold light.
Transmission:
64. 3-2 timing solenoid valve.
What does this do? Is it part of solenoid pack?
ABS:
11. Right front wheel speed sensor or rotor.
Weird as the ABS fuse is missing so would have thought whole lot would fail.
Engine:
9. Water Thermosensor (EGI).
What and where is this?
No idea:
36. *Not on list*
I checked it 3 times and got 2 other people to check too. Definitely 36 flash code.
Any help much appreciated.
Thanks,
Alan
Re: Help with Diagnostic codes
Post by Ian » Fri Jul 06, 2018 8:25 am
Transmission fault code 64 is also known as "Pressure Control Solenoid". It's included in the pack (I think) and can be obtained from https://mazdabongo.com/catalog/mazda-bo ... ic-models/
ABS Code 11: I seem to remember something like this happening before. If the ABS fault has not cleared the system it will display code 11. The ECU probably needs resetting.
Engine Code 9 is also known as "Engine Position System Performance - Bank 2" But I don't know what that means either
On some lists code 36 is "Heater Circuit Malfunction"
What year is your Bongo?
WebWiz
Post by WebWiz » Fri Jul 06, 2018 8:36 am
It's a 1996 model SGL5.
The front fans don't do a great deal unless they are on full. I read on here that there is a replacement resistor I believe. Could that be the fault?
Do you know how to clear old fault codes as I don't want to chase my tail over faults that are no longer relevant.
Thanks,
Alan
Post by Ian » Fri Jul 06, 2018 12:23 pm
This is how to reset the fault codes
1)Remove the wire from the negative terminals for at least 20 seconds. 2) Click on the brake pedal and release. 3)Re-connect negative battery terminal. 4) Start engine, and run for 3 minutes at 2,000 rpm idle.
Yes, it sounds like a new resistor may be required. There are 2 types. One for slide control aircon, one for digital climate control. You will find them in the Bongoland shop at https://bongoland.co.uk/product-category/electrics/
Post by teenmal » Fri Jul 06, 2018 2:26 pm
WebWiz wrote: Fri Jul 06, 2018 8:36 am It's a 1996 model SGL5.
Thanks,
Alan
Are you referring to the Rad cooling fans or the heater blower?
WebWiz
Post by WebWiz » Fri Jul 06, 2018 2:28 pm
Sorry. that was about as clear as mud.
I meant the front cab heaters. Rad fans are fine.
Post by g8dhe » Fri Jul 06, 2018 3:07 pm
The air-con fan has a habit of corroding up as overspill water from the window screen falls down directly on top of it. First clear out the drainage pipe from the window screen. second remove the fan and give it a good through clean as per these pictures Image
and whilst your at it also give the cooling matrix a clean as well as all the air passes thru it and it gets clogged up!
WebWiz
Post by WebWiz » Fri Jul 06, 2018 3:15 pm
Awesome. Thanks.
I'll add that to the list of things to do once it stops overheating. Until then the boiling over is my main concern.
Back to transmission... Does anyone know if the solenoids can be cleaned? Does the ECU report error if they don't open properly, ie. if they're blocked, or does it just report electrical faults such as open circuit and wrong resistance?
