Rear seat not sliding smoothly (converted seats)
Calum
Post by Calum » Mon Jul 02, 2018 8:06 pm
Hi all
I've got a 2001 (new look) Bongo with Mistral full side conversion. The rear seats were cut down to 2 passengers each. Looks like that was done with a big saw and some welding - clever stuff.
The middle seat glides back and forth beautifully, but the back seat is hard work. It doesn't grind or get stuck, it's just very resistant - even over the same bit of track as the middle seat.
Has anyone got any ideas about what might be causing this? I'm afraid that when welding back together the runners are slightly mis-aligned or something. Or could there be another cause? (one that's more fixable?)
Calum
Calum
Re: Rear seat not sliding smoothly (converted seats)
Post by Bob » Tue Jul 03, 2018 8:43 am
Could you contact the converter?
Flanners
Post by Flanners » Tue Jul 03, 2018 8:07 pm
Try a shot of spray grease or WD40/GT85 derivate on the runners
Calum
Post by Calum » Tue Jul 03, 2018 10:33 pm
Thanks Bob & Flanners, I'll give WD40 a go initially, and then try contacting the people who made the conversion. I'll report back :)
Calum
Jimbobvfr400
Post by Jimbobvfr400 » Fri Aug 17, 2018 9:33 pm
I've got a similar setup in mine. It might be worth unbolting the seats and seeing if the runners themselves are stiff to slide or if it's only when the seats are bolted up.
I reckon if the seats aren't quite as accurately made as they could be then it could be the seats themselves forcing the runners to not quite run smoothly. If they still move it can't be out by much so maybe a slight fettling with a file on the bolt holes could be enough.
Jamie, Caroline and the kids.
2002 V6 Aero AFT
Calum
Post by Calum » Thu Aug 20, 2020 9:02 pm
After some investigation I think that the sliders are actually not quite parallel. They will move, so it's not the end of the world.
Calum
Post by Bob » Thu Aug 20, 2020 9:16 pm
Thanks.
An update is always useful for the future. 8)
