Coolant level - how to check
Posted: Sat Jun 23, 2018 8:12 am
by Evertonskidog
Hi guys. I’m new to this forum - thrilled to join!
We purchased our bongo last week after many weeks of researching on here.
The new vehicle doesn’t have a coolant alarm (which I’ll look to do ASAP) but I have another issue. This may sound odd but I am unable to check how much coolant is in the vehicle. If I open the chamber I can see fluid inside but I cannot see through the chamber to see if it’s above the min limit. Is this normal? I even used a torch. No joy.
Ofcourse I am worried that I can’t see how much fluid is in there because there isn’t enough to register!
For info I place a clean rod into the tank and there was about an inch of fluid on the bottom
Big apologies if posted elsewhere - I did search first.
Re: Coolant level - how to check
Posted: Sat Jun 23, 2018 8:45 am
by Bob
Hi, and welcome aboard.
Your 'clean rod' method is perfect. I've seen 3/4" or 20mm recommended so the inch you're reading is about right.
I find the little sticks you get for stirring coffee just right.
Excuse for a visit to Spoonies.
Posted: Sat Jun 23, 2018 8:48 am
by Markas
There is a method involving using a lolly stick as a dipstick - I'm sure it's somewhere on here or in a how-to file. An inch from the bottom sounds low to me. Try checking in different light levels - if my expansion tank is in bright sunshine (rare i know!) I can't see the contents.
Oh, and welcome to the forum!!
Posted: Sat Jun 23, 2018 8:49 am
by Markas
Bob beat me to it & I bow to his superior knowledge
Posted: Sat Jun 23, 2018 11:55 am
by Bob
I'm not claiming that.
Posted: Sat Jun 23, 2018 1:32 pm
by WebWiz
I've just been struggling with my cooling system and topped up tank countless time the last few days.
I found that placing my phone's camera flash/torch on top of the tank or over the opening allows me to see the level but that's in the shade.
If very cloudy/stained tank then the stick method also works well as this is what I first used before discovering the torch method.
Posted: Mon Jun 25, 2018 9:57 am
by haydn callow
Stick with the stick method, just make sure you do it cold and keep the stick vertical, 2 cms showing on the stick is perfect a bit more/less is ok
Posted: Tue Jun 26, 2018 1:12 pm
by Doone
Yes any stick, marked 2cms from the end you're going to dip. If the 2cm line is wet, the level's OK.
Posted: Tue Jun 26, 2018 2:34 pm
by teenmal
You could also use a marked straw . dip it put your finger over the hole lift up and read.
Posted: Wed Jun 27, 2018 9:01 pm
by SimonD
I also use a marked stirrer but found that if I stick my right hands' little finger in to the tank filler hole ( with the rest of my hand spread in front of the tank in line with the vehicle so to speak), for me it is exactly the right level if I can _just_ reach the coolant with the tip of my pinky.
ONLY IF coolant is definitely, definitely COOL!!!!
Obviously I wash/clean my finger ASAP and perhaps not the best method for those sensitive, or of a nervous disposition, but measurement wise, it works for me.
Posted: Thu Jun 28, 2018 9:01 am
by teenmal
Posted: Thu Jun 28, 2018 1:37 pm
by Bob
We'll have to make up a little jig and offer 'finger calibrating' at Stourport.
Posted: Thu Jun 28, 2018 3:34 pm
by Doone
