Torque converter clutch solenoid
Posted: Tue Jun 05, 2018 10:13 pm
by timhowes
Hi folks
Going on a long-ish trip to France in my van in 6 days and am trying to ascertain whether I'm likely to encounter trouble. Thanks to Geoff and Julian via FB who have helped with this so far.
Problem: flashing hold light. No symptoms, drives as smoothly as at purchase 2 years ago (2000 V6).
Ran diagnostics and got error P0743. Google suggests this is to do with torque converter clutch solenoid.
Is this something I should look into before going? I have a trusted (but not cheap) local Bongo specialist in Bristol but no idea whether they'll have the part.
As I say, all is running fine and transmission seems normal. Sump pan looks kind of greasy from underneath, not sure whether I should be worried about ATF leak in this context.
Any advice much appreciated.
TIA
Tim
Re: Torque converter clutch solenoid
Posted: Wed Jun 06, 2018 9:00 am
Have you checked ATF level (i think it has to be checked with engine running and gearbox in D but check on that) and the condition of it. If you can get hold of him on here, BF member Alacrity (Geoff) might give a view as he's an autobox specialist and erstwhile Bongo owner. Good luck, keep us posted.
Posted: Wed Jun 06, 2018 9:34 am
by timhowes
Thanks Mike, was reading Alacrity's very helpful posts regarding a similar issue just last night. I'll contact him
Posted: Wed Jun 06, 2018 9:42 am
by teenmal
Put the gearstick in 'Park' (P) position hand brake on engine running , check fluid level.
Posted: Wed Jun 06, 2018 9:51 am
teenmal wrote: Wed Jun 06, 2018 9:42 am
Thanks teenmal - never can remember the details so yours mechanics correction is welcome.
Posted: Wed Jun 06, 2018 9:42 pm
by timhowes
Thanks all. Checked fluid, level good and looks/smells normal. Spoke with local Bongo garage who say likely to be solenoid but not to worry if no symptoms. Planning to do my 2 week trip in France next week and book it in for a look on return. I don't fancy the solenoid change myself having watched vids of the ATF drain process, have zero mechanical expertise apart from pedal cycles!
Posted: Thu Jun 07, 2018 11:03 am
timhowes wrote: Wed Jun 06, 2018 9:42 pm
Fingers crossed for you and let us know how you get on.
Posted: Thu Jun 07, 2018 11:36 am
by teenmal
Call me old fashioned But I would (personally) get it checked out before the journey.
Posted: Thu Jun 07, 2018 6:36 pm
by timhowes
Thanks for that. No time, hence spoke with garage and they reassured me.
Watch this space... Have purchased breakdown cover today!
Posted: Sat Jun 09, 2018 9:33 pm
by knpenny
where in france are you going, i live here and may be able to help if you get into trouble. Have a good trip and good luck
