Sliding door motor issue?
Redpepsi31
Post by Redpepsi31 » Tue May 22, 2018 2:50 pm
Didn't realise until my mate brought their Bongo round that the sliding door had an electric soft closure feature.
Mine doesn't function at present.
Can somebody point me in the right direction regarding a fix please.
It's a 98 2.5 model.
Thank you
Re: Sliding door motor issue?
Post by Bob » Tue May 22, 2018 5:38 pm
First thing to try is clean the contacts on the door and pillar. :wink:
Redpepsi31
Post by Redpepsi31 » Tue May 22, 2018 6:38 pm
Thanks Bob.
I'll report back shortly.....
Redpepsi31
Post by Redpepsi31 » Tue May 22, 2018 8:12 pm
All contacts cleaned still not working sadly.
No motor sound whatsoever on closure.
Any other thoughts or ideas would be much appreciated.
Thank you
knpenny
Post by knpenny » Tue May 22, 2018 8:52 pm
If there's no motor sound at all, it would suggest its not getting power, I'd check the fuse for it first, in the fuse box it is a 15a fuse, on the bottom row of 4 fuses on the left, and if thats ok then i'd be looking into the the door itself, take off the inner panel and it could just be a connection has came off or loose. Or worst case scenario, the motor is gubbed but i hope its just the fuse. good luck :wink:
Bongology, the study of all things bong. The bongologist. :shock:
Markas
Post by Markas » Tue May 22, 2018 8:55 pm
They don't all have the soft close feature do they?
I've always assumed mine is slam-o-matic! Great when you need a pee on site at 3am :roll:
Mark
Post by teenmal » Tue May 22, 2018 10:09 pm
Markas wrote: Tue May 22, 2018 8:55 pm They don't all have the soft close feature do they?
You are probably correct it could be an optional extra,but I would imagine if the contact assy is present that function would be installed.
Markas
Post by Markas » Wed May 23, 2018 7:41 am
teenmal wrote: Tue May 22, 2018 10:09 pm
There is a contact assembly on the B post with some round brass contacts. I thought that was for the door open warning light - may be having a poke around sometime!
Mark
Post by g8dhe » Wed May 23, 2018 11:02 am
Door open switch is at the rear of the door "C" pillar, down low activated as the back of the door swings in. The front contacts are three for closing and two (recessed) for door lock.
BongoBongo123
Post by BongoBongo123 » Wed May 23, 2018 12:08 pm
g8dhe's Bongo knowledge is top class, just thought I would say ! Top man.
They call me light foot.
Redpepsi31
Post by Redpepsi31 » Thu May 24, 2018 9:04 am
All contacts cleaned up , fuses checked all fine .
Switch on C pillar is free and moves in and out when i press it .
I presume its time to remove the sliding door panel and investigate further.
Can anybody indicate what i should be looking for please?
Will I need to remove the circlip off the door handle or can i just lift the panel to examine the motor area?
Thanks again for all your help .
Post by g8dhe » Thu May 24, 2018 9:50 am
You need to remove the door handle, hence removing the clip at the rear, before the door card can be removed.
Markas
Post by Markas » Sat May 26, 2018 1:08 am
BongoBongo123 wrote: Wed May 23, 2018 12:08 pm g8dhe's Bongo knowledge is top class, just thought I would say ! Top man.
Second that! I just have the two door closed contacts then :(
Mark
Redpepsi31
Post by Redpepsi31 » Thu May 31, 2018 9:18 pm
Used soft closure motor purchased for £12 plus carriage.
Fitted today working a treat .
Thanks to everyone for their input and guidance .
Post by Bob » Thu May 31, 2018 9:27 pm
Sound. =D>
