2001 Aero tin top air con not working properly
sid14
Post by sid14 » Fri Apr 20, 2018 5:23 pm
Hi my 2001 2l petrol has developed a problem with the air con, it's has a digital display and no matter what mode is selected the air only goes to the foot well unless you put to demister.
I don't what to buy a new unit if I should check anything else that could cause it HELP please. :(
Re: 2001 Aero tin top air con not working properly
Post by g8dhe » Fri Apr 20, 2018 6:28 pm
Check out the links in the drivers footwell image below covers all links and air con types;
http://www.g8dhe.net/bongo_images/airco ... -flaps.JPG
sid14
Post by sid14 » Fri Apr 20, 2018 11:24 pm
Thanks Geoff I check them out in the morning and let you know☺
sid14
Post by sid14 » Sat Apr 21, 2018 6:44 pm
Hi Checked the linkages and no joy they all are ok, so have to bite the bullet and buy a new digital control unit lol.
Post by g8dhe » Sun Apr 22, 2018 2:30 pm
Is the servo moving when you select different settings ? If not disconnect that link and see if the servo moves, more likely to be a mechanical problem then an electronic one, if that doesn't identify the fault might be worth checking the servo itself out, may be able to swap with the one in the passenger footwell not sure if they are the same or not ...
sid14
Post by sid14 » Sun Apr 22, 2018 7:15 pm
Thanks Geoff
I will give that a go when I'm back from doing diy at my daughters and see what happens, will keep you posted.
sid14
Post by sid14 » Sun Apr 29, 2018 11:38 pm
Good news the problem was caused by a cable coming loose from its anchor point and stopping the vent from opening. It was from the fitting of an after market alarm system.
