V6 Will not start
newbongoowner
V6 Will not start
Post by newbongoowner » Fri Apr 06, 2018 11:56 pm
Hi everyone
Had the bongo since end of season last year and no problems until today, after a 40 min drive it failed to restart after being turn off for 5 minutes. No dash light at all and no cranking of the engine. Tried jumping off my work van too but nothing. Changed 100a fuse no change.
I think it points to a flat battery (new 5 months ago but on charge as I type) but cant jump it and surely dash lights would light up even if there dim but nothing at all.
Headlights/wipers/indicators were working
Heating module on dash lights up but when I turn the ignition key to position 2 to start/crank it turns off completly.
Seen a few posts regarding the solenoid in the starter motor could need replacing but would still see dashboard lights?
No alarm or immobiliser installed but the leisure battery seems to drain quite quickly, thought it was the new head unit so installed a seperate rocker on/off switch.
Any help would be much appreciated
Bongolia
Re: V6 Will not start
Post by Bongolia » Sat Apr 07, 2018 1:59 am
Could be a number of things and this is just a long shot but... when you have the battery fully charged and refitted to the van and if that alone has not cured the problem, then take the jump lead and clip onto the negative battery post and connect the other end to a good earthing point on the engine itself, connect two leads together if you need the extra length. Try that first to eliminate a poor/broken earth.
Is the 100 amp fuse the OP refers to the fusable link?
Does the Bongo even have one?
newbongoowner
Post by newbongoowner » Sat Apr 07, 2018 8:01 am
Thanks for the reply
I am not sure what you mean regarding the 100a fuse? I changed it as i assumed that with not dash lights or solenoid click that there must be no power at all going to the starting circuit.
Billybongo123
Post by Billybongo123 » Sat Apr 07, 2018 10:01 am
As above, also check battery connections and ignition relay.
We love our rusty Bongo "Billy", despite his many faults!
newbongoowner
Post by newbongoowner » Sat Apr 07, 2018 8:08 pm
Thanks for the replys
Got an auto electrician out in the end and it turned out to be a blown 15a fuse below the dashboard, it was marked as 'meter', as soon as it was changed started on the button.
Going to carry a small multi meter and many fuses from now on, lots cheaper than £130!!
Billybongo123
Post by Billybongo123 » Sat Apr 07, 2018 8:12 pm
There's no labels in my fuse box lid, can you send me a pic of your diagram lol?
newbongoowner
Post by newbongoowner » Sat Apr 07, 2018 9:39 pm
Tried to upload a photo of my japanese manual to show where/what fuses are for what but file to large, PM me your email and will send it over
Post by g8dhe » Sat Apr 07, 2018 10:42 pm
All the fuses, lamps and problems as well as diagrams are listed on the Wiring manuals site http://www.g8dhe.net/bwm suggest you bookmark it for when your out and about.....
Billybongo123
Post by Billybongo123 » Sat Apr 07, 2018 10:53 pm
g8dhe wrote: Sat Apr 07, 2018 10:42 pm All the fuses, lamps and problems as well as diagrams are listed on the Wiring manuals site http://www.g8dhe.net/bwm suggest you bookmark it for when your out and about.....
Thanks buddy
