Thinking of going to the dark side. Mot history jitters
Posted: Fri Jan 05, 2018 2:55 pm
Well after 6 fabulous years of Ford Freda ownership we're thinking of going to the dark side and are considering a VW t5 conversion. The bongo's just not big enough for us now the kids are growing and we've always been too scared to take it abroad. Not because it's ever let us down but because we're just chickens.
Sadly our pockets aren't particularly deep so we're looking at the more budget end of the range.
We've seen a 55 plate van that ticks all the boxes and is in our price range but the MOT history is worrying me a little as there have been a lot of suspension related fails over the last few years.
The cambelt and waterpump were changed last year and I know how to check for issues with the dual fly mass wheel but I'm not particularly mechanically minded.
I know this is a bongo forum but I've always had such good help here in the past I'm just hoping someone could have a look at the mot history and tell me if it's all just normal wear and tear considering the age and mileage or if we should avoid.
Copy of MOT results below.. Oh and if anyone is looking for a freshly MOTd unconverted 97 AFT ours will be up for sale shortly (and with regret as we've loved owning it).
I've been trying and failing to join the T5 forum but for some reason can't get past the registration stage.
Skip to main content
GOV.UK
Check MOT history
BETA This is a new service. Complete a quick survey to help us improve.
Back
VF55DNY
VOLKSWAGEN TRANSPORTER
Check another vehicle
Colour
White
Fuel type
Diesel
Date registered
14 December 2005
MOT valid until
4 August 2018
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal. (Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Open All
MOT History
Mileage recorded at test, parts failed or had minor problems
Date tested
1 August 2017
PASS
Mileage
141,279 miles
MOT test number
8742 1919 6522
Test location
unavailable until further notice
Expiry date
4 August 2018
Date tested
1 August 2017
FAIL
Mileage
141,277 miles
MOT test number
6457 8753 6702
Test location
Reason(s) for failure
Offside Front Front constant velocity joint gaiter insecure to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
Offside Registration plate lamp not working (1.1.C.1d)
What are failures?
Date tested
5 August 2016
PASS
Mileage
126,192 miles
MOT test number
8838 1069 7167
Test location
Expiry date
4 August 2017
Advisory notice item(s)
engine mounting worn
What are advisories?
Date tested
5 August 2016
FAIL
Mileage
126,191 miles
MOT test number
9324 6944 0414
Test location
Nearside Front Lower Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
Offside Front constant velocity joint gaiter insecure to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
Horn not working (1.6.2a)
What are failures and advisories?
Date tested
5 August 2015
PASS
Mileage
116,834 miles
MOT test number
8417 1781 3651
Test location
Expiry date
4 August 2016
Nearside Front Anti-roll bar has slight play in a pin/bush (2.4.G.2)
Offside Front Anti-roll bar has slight play in a pin/bush (2.4.G.2)
Nearside Front Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
Offside Front Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
Date tested
30 July 2015
FAIL
Mileage
116,795 miles
MOT test number
4611 1518 3149
Test location
Offside Front Inner Front constant velocity joint gaiter damaged to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
Nearside Rear Stop lamp not working (1.2.1b)
Date tested
30 July 2014
PASS
Mileage
99,167 miles
MOT test number
8993 1151 4287
Test location
Expiry date
29 July 2015
Date tested
30 July 2014
FAIL
Mileage
99,167 miles
MOT test number
2884 2111 4296
Test location
Nearside Rear coil spring broken (2.4.C.1a)
Offside Rear coil spring broken (2.4.C.1a)
Nearside Front Anti-roll bar linkage has excessive play in a pin/bush (2.4.G.2)
Rear Registration plate lamp not working (1.1.C.1d)
What are failures?
Date tested
4 September 2012
PASS
Mileage
86,935 miles
MOT test number
7968 9874 2297
Test location
Expiry date
3 September 2013
Front Brake pad(s) wearing thin (3.5.1g)
Rear Brake pad(s) wearing thin (3.5.1g)
Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Nearside Front Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Offside Front Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
spare tyre soft
Date tested
4 September 2012
FAIL
Mileage
86,935 miles
MOT test number
8466 3864 2203
Test location
Nearside Front Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
Offside Front Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
spare tyre soft
Date tested
20 May 2011
PASS
Mileage
77,500 miles
MOT test number
8467 5034 1170
Test location
Expiry date
19 May 2012
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Date tested
9 September 2010
PASS
Mileage
71,340 miles
MOT test number
1726 1255 0230
Test location
Expiry date
8 September 2011
Date tested
26 March 2010
PASS
Mileage
67,418 miles
MOT test number
1349 5588 0401
Test location
Expiry date
25 March 2011
Nearside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Date tested
5 December 2008
PASS
Mileage
55,382 miles
MOT test number
7521 4004 8319
Test location
Expiry date
14 December 2009
Outstanding vehicle recalls
Check if VOLKSWAGEN TRANSPORTER has outstanding safety recall
Support linksCookies Terms and conditions Privacy policy MOT history API Built by the Driver & Vehicle Standards Agency
Open Government Licence
All content is available under the Open Government Licence v3.0, except where otherwise stated
© Crown copyright
GOV.UK
Check MOT history
Back
VF55DNY
Colour
White
Fuel type
Diesel
Date registered
14 December 2005
MOT valid until
4 August 2018
Open All
MOT History
Date tested
1 August 2017
PASS
Mileage
141,279 miles
MOT test number
8742 1919 6522
Test location
Expiry date
4 August 2018
Date tested
1 August 2017
FAIL
Mileage
141,277 miles
MOT test number
6457 8753 6702
Test location
What are failures?
Date tested
5 August 2016
PASS
Mileage
126,192 miles
MOT test number
8838 1069 7167
Test location
Expiry date
4 August 2017
Date tested
5 August 2016
FAIL
Mileage
126,191 miles
MOT test number
9324 6944 0414
Test location
Date tested
5 August 2015
PASS
Mileage
116,834 miles
MOT test number
8417 1781 3651
Test location
Expiry date
4 August 2016
Date tested
30 July 2015
FAIL
Mileage
116,795 miles
MOT test number
4611 1518 3149
Test location
Date tested
30 July 2014
PASS
Mileage
99,167 miles
MOT test number
8993 1151 4287
Test location
Expiry date
29 July 2015
Date tested
30 July 2014
FAIL
Mileage
99,167 miles
MOT test number
2884 2111 4296
Test location
What are failures?
Date tested
4 September 2012
PASS
Mileage
86,935 miles
MOT test number
7968 9874 2297
Test location
Expiry date
3 September 2013
spare tyre soft
Date tested
4 September 2012
FAIL
Mileage
86,935 miles
MOT test number
8466 3864 2203
Test location
spare tyre soft
Date tested
20 May 2011
PASS
Mileage
77,500 miles
MOT test number
8467 5034 1170
Test location
Expiry date
19 May 2012
Date tested
9 September 2010
PASS
Mileage
71,340 miles
MOT test number
1726 1255 0230
Test location
Expiry date
8 September 2011
Date tested
26 March 2010
PASS
Mileage
67,418 miles
MOT test number
1349 5588 0401
Test location
Expiry date
25 March 2011
Date tested
5 December 2008
PASS
Mileage
55,382 miles
MOT test number
7521 4004 8319
Test location
Expiry date
14 December 2009
© Crown copyright
