Re: Pinouts for CL fob reciever please
Posted: Wed Dec 13, 2017 4:45 pm
The lock solenoids for all the other doors use a reversing connection, rather than a pulsed connection. I would assume that the original drivers door lock option used the same method, so you would need to select that option in the new system and no doubt also run a pair of wires into the door using the same route as the drivers door loom from the control unit unless it is door mounted.
