No side lights or brake lights or dash lights
Posted: Fri Nov 17, 2017 10:23 pm
by mfc1476
Hi my side lights ,brake light,dash lights fog lights all stopped working today any ideas ? I tried switching the relays around under the bonnet on the near side inner wing but no joy. Still have headlights and indicators.
Re: No side lights or brake lights or dash lights
Posted: Fri Nov 17, 2017 11:16 pm
The Side lights, Dash lights are all switched by the relay on the nearside front bumper second from rear and common fuses.
The Brake lights and Fog lights are all from separate circuits as well.
Is there any other history, any work done recently, did they all go together or have you only just spotted that they aren't working, what year of vehicle is it ?
More information on fuses and lamps is available on the Wiring Manuals page here see the Tab for fuses and Problems;
Posted: Fri Nov 17, 2017 11:58 pm
by mfc1476
I think my 3yr old son has been playing with the indicator stock and this is the problem. Does anyone know how to open it up.I can see a small panel on the rear of it with a small hole .Just to be clear I am trying to open the end with the sidelight headlight selector.
Posted: Sat Nov 18, 2017 12:07 am
by mfc1476
Hi Geoff the relay seems ok when I change the side light fuse under the bonnet they work for a few seconds and I can hear the relay click .The van is a 98 2.5d .There has been no work carried out lately it has been running great for a long time.They all went at the same time.I noticed dash first then side lights when I opened door and no buzzer so I then checked the rest and had no brake lights
. My 3yr old was left in the van for 5 min and when I came back he was playing with the controls so now thinking it might be stock.
Posted: Sat Nov 18, 2017 10:22 am
I can't think how the brake light can be associated with the a problem with the light stalk to be honest. I assume the engine is running OK since the problem developed?
When you say the sidelights work for a few seconds after changing the fuse, do you mean the fuse was blown and has blown after a few seconds again?
Posted: Sat Nov 18, 2017 11:18 am
by mfc1476
The brake lights are working now changed fuse the sidelights still out as soon as I replace fuse it blows could this be an earth problem
Posted: Sat Nov 18, 2017 12:13 pm
Depends what you calling an Earth problem! Most Earth problems are bad connections caused by rust and corrosion, that won't be your problem if its blowing a fuse! More likely a blown lamp which is shorting out or a damaged wiring loom and the earth is making contact with the +12v supply.
