Coolant alarm not working
Posted: Mon Aug 28, 2017 8:00 am
I think there was a coolant alarm fitted to my bongo before I bought it, but it's not working (found out the hard way!). There's 2 sensors screwed to the header tank, The wires lead across the engine to the rubber seal on the drivers side, but then I don't know where they go.
Is there a normal place for the alarms to be fitted so I can check it hasn't been removed at some point?
Are there any common faults that might be causing it to not be working?
There's a little black switch below and to the right of the steering wheel which I have turned on, I presumed that controls the alarm but hasn't gone off when I've drained the system or when it overheated and ran dry.
Is there a good way to test without draining the coolant system and having to bleed? I have an unidentifiable leak (suspected head gasket or cracked engine block which aren't worth fixing given the age and condition of my bongo) so planning to rely on the alarm until my bongo inevitably finally gives up
Any advice much appreciated
