scavenger fan
Posted: Sat Aug 12, 2017 2:36 pm
what is it where is it what does it do?
Its a FAN for moving air around!what is it
Directly in front of the engine, pointing upwards slightly, you can see it when the seats are up look down the front,its in a cage.where is it
Keeps the engine housing cool when your stationery and the air isn't flowing over the engine, otherwise the seats and centre console would get rather hot.what does it do?
Yes i think you can test it using e.g. a hairdryer (the sensor is near the handbrake i think) but why bother when an engine temp block gauge and over-ride will produce a happier and more reliable state of affairsJoeC wrote:Is there anyway of testing the scavenger fan sensor to make sure it is working properly?
Cheers but how do I know that it is kicking in and switching off at the correct setting?mikeonb4c wrote:Yes i think you can test it using e.g. a hairdryer (the sensor is near the handbrake i think) but why bother when an engine temp block gauge and over-ride will produce a happier and more reliable state of affairsJoeC wrote:Is there anyway of testing the scavenger fan sensor to make sure it is working properly?
You'd need a thermometer and a value for when it should kick in? But i suspect that if a hairdryer activates it at all then its working properly.JoeC wrote:Cheers but how do I know that it is kicking in and switching off at the correct setting?mikeonb4c wrote:Yes i think you can test it using e.g. a hairdryer (the sensor is near the handbrake i think) but why bother when an engine temp block gauge and over-ride will produce a happier and more reliable state of affairsJoeC wrote:Is there anyway of testing the scavenger fan sensor to make sure it is working properly?
.....and it'd be simpler and more useful to fit a tm2 and over-ride switch? Just sayingteenmal wrote:The values are ..
20c 2.0~2.9
80c 0.27~0.37
You need a container for water ,multi meter,heat source for the water , thermometer and some black cats Whiskers.
