Page 1 of 2
Carrying skinny spare on the back door
Posted: Tue Jun 20, 2017 2:31 pm
by langtoftnick
Can this be done? Anyone done it? Anyone recommend a bracket manufacturer?
Issues with number plate, lights? Uprating door gas struts????
I did search the fora but couldn't find anything.. maybe it's so easy no one has had to ask anything before!
Thanks guys and gals.
Nick
Re: Carrying skinny spare on the back door
Posted: Tue Jun 20, 2017 2:35 pm
by Bob
I'm pretty sure long standing friend of the Forum Simon Jones has done this.
He got back in touch just recently so with luck he will be along to help, otherwise just click his profile and search all his posts.
Edit:
http://igmaynard.co.uk/bongo/forum/view ... or#p646539
Posted: Tue Jun 20, 2017 6:55 pm
by Simon Jones
Aye, 'twas me. Must admit I nicked the idea from former member Ron Miel and tweaked the design a bit. Will be at the Bash with wheel fitted if anyone wants to see it in action.
It's a modified pair of trailer spare wheel mounting brackets which clamps round the ladder rung which is covered in a piece of coolant hose.
You will need some extra support to take the weight as the gas struts won't hold it up. I use some round plastic conduit with a split cut to allow it to sneck over the strut.
Posted: Tue Jun 20, 2017 8:26 pm
by Bob
Bear in mind the age of the tyres.
I've an idea Simon managed to get hold of a new skinny, but the originals will be 20+ years old, and all that time in the road muck under a Bongo.
Posted: Tue Jun 20, 2017 9:54 pm
by langtoftnick
Thanks everyone.... Shame I don't have a ladder! Also looks like obscures a lot of the rear window. Shame the bak rak is so huge and ugly... And then covers the number plate...
Thinking cap on time.
Posted: Tue Jun 20, 2017 10:45 pm
by Bob
Posted: Wed Jun 21, 2017 10:26 am
by Bob
And it popped into my head that you would be able to fit a full size spare on a rack like this.
Posted: Wed Jun 21, 2017 10:43 am
by langtoftnick
Had words with bak rak.. they are in the process of marketing a new design which isn't so huge. It apparently just has a stem and a plate which you bolt the spare to which will be much neater.
On the subject of space savers.
The T135/90 R15 has a rolling cicumference of 77.1"
Standard 215/60 r16 has circumference of 82.1"
If the skinny was on a 16" rim it would be 80.3" which is -2.3% and even that is outside recommend +/- 1%
So how the hell would anyone ever have used a standard skinny spare for even a mile without shredding their diff?
Posted: Wed Jun 21, 2017 11:24 am
by rita
The differentials use planetary gears which compensates for different rotation/speeds of the road wheel (hence the name Differential )and if the vehicle is 4WD it uses a Viscous coupling.
Supplying these vehicles with the (Skinny) is designed by the Manufactures of the vehicle and should not present a problem if the recommended use is adhered too.
Good Luck...
Posted: Wed Jun 21, 2017 2:07 pm
by Bob
Interesting point, but you would think Mazda know what they're about.
Standard size is 215/65/15.
Posted: Wed Jun 21, 2017 4:42 pm
by rita
Bob wrote:Interesting point, but you would think
That's what was said.....
"Supplying these vehicles with the (Skinny) is
Posted: Wed Jun 21, 2017 5:13 pm
by Bob
I know, I was agreeing with you.
Posted: Thu Jun 22, 2017 12:02 am
by Simon Jones
Bob wrote:Bear in mind the age of the tyres.
It's same tyre as fitted to Honda Civics so plenty of much younger skinny wheels and tyres available on eBay but the wheel won't fit so you'll need to swap tyre to Mazda wheel. I had mine powder coated to match the alloys and 4 or 5 years on it's still rust-free.
Posted: Thu Jun 22, 2017 12:12 am
by Bob
That's really valuable info Simon.
Thanks, this will help a lot of peeps.
Posted: Thu Jun 22, 2017 12:27 am
by Simon Jones
Worth checking the size as I can't recall what year Civic I bought mine from. If you stick the tyre size into eBay, you'll get a number of matches and the one I got came on a nice yellow space-saver rim which I've still got sat in the garage somewhere.
