One of my "roof closed" sensors is faulty as the rubber button part has perished, so I wondered how possible it is to replace?
Do both switches on each side need to be engaged for the roof up warning light to go out? I have a suspicion that only the drivers side switch makes the warning light go out, and the left hand one makes the AFT roof illumination light go out. I am happy to be corrected.
Anyway, both the switches are faulty as the roof warning light is on. My modification to both sides worked for a while (I glued extra plastic onto the pushers to engage the switch), but now they are playing up again. So:
- Can the micro switches be removed, or do you have to cut their wires etc??
And, can you get replacement ones?
