Hello.
I've in intermittent brake problem. The brake pedal feels like abs has kicked in and after a judder, it sinks lower to the floor. Brakes still work although van pulls to the right.
However, I get a warning in the form of a whooshing sound from air vents. When I hear this I know the brakes are going to be funny.
Thought it could be air being sucked in to vacuum pipe to servo but no obvious split. If I pump brake when ignition is off, it does build pressure as expected before easing when ignition is on.
Any ideas? A cheap and easy fix would suit me just fine!!
Thanks,
Charlie
Whooshing noise, brake problem. Servo?
- BongoBarrow
- Bongonaut
Mor'du is a Black 1995 2.5l diesel Auto 4x4 Converted - Auto Free Top and will be tamed!
