Idle speed control petrol engines
Posted: Wed May 17, 2017 1:33 pm
Long one coming up!
As there has been a couple of queries regarding idle problems on petrol engine and as it Pizzin down with rain I thought it may be helpful to some peeps to cover how to check the idle circuit on the petrol Bongos.
So here goes.....
The images here are for a 2.0ltr but the principle is likely the same for the v6.
When the engine is idling and is presented with an additional load the idle needs to automatically increase to compensate for that load to avoid stalling. When your foot is off the accelerator a switch at the the throttle quadrant tells the ECU to switch to an idle setting and the idle regulation is then dealt with on the Bongo V6 and 2/0Ltr petrol engines by an air valve. In order to do this effectively the ECU needs complete control of the amount of air the engine is receiving. Mazda call this device a BACS unit. I shall incorrectly call this the ISCV from here on.
BACS valve or ISCV image and its pipework.
https://goo.gl/photos/ywNTMv3J3afVTjZu8
When the Bongo leaves the factory a base idle is setup this is achieved by taking control from the ECU and adjusted by the air bleed screw at the top of the plenum. You will not be able to satisfactorily adjust the idle without switching the ECU out of control.
You shouldn't need to do this but I will cover the process later.
Here is the air bleed screw and below it the evap pipe you will need to check later.
https://goo.gl/photos/2VjHftvWfq55ekv76
The most common cause of erratic idle is air entering this circuit from split or leaking air pipes or a dirty or malfunctioning ISCV.
So starting with a series of basic checks for the pipework.
The Evaporation unit.
https://goo.gl/photos/KH72hCVtdCmYFdUj8
On the near side attached to the chassis rail you will see a black plastic canister next to that that is a small solenoid (purge valve with the electrical connetion) this degases the fuel tank when you start up
Gasses build up in the fuel tank for a number of reasons emissions regs require these vapours are held in the system and then fed back into the inlet when the engine starts,this black canister is where they are held.
On later vehicles, OBD2 on, the opening of the purge valve is done by the ECU based on readings it receives from sensors around the engine. So if yours is OBD2 then it may trigger differently.
Prior to OBD2 they are simpler in operation.
Switch on the ignition and listen for a click from the purge valve on the canister
If yes this would indicate the solenoid is working, it could still fail internally (mechanically) but usually if they click they work.
Next disconnect the pipe from the inlet manifold to the evap solenoid, ignition off. Put the pipe from the solenoid in your mouth and suck baby, you should have resistance, while holding the suck get someone to switch the ignition on but not cranking. You should note a momentary loss of vacuum. You can use a vacuum gauge for this but this is more fun just be aware you could get some petrol in yer cakeole.
If you are drawing air from here and cannot get a vacuum then you have an issue with the evap. This is unlikely as they normally fail closed.
Anyhow you can take that out of the circuit for the rest of the checks for now by refitting the pipe and clamping it off, if this resolves the problem the swop out the solenoid after checking for a supply voltage.
To do the rest of these checks more easily you will need remove the center section above the engine the bit that holds the gear selector, careful with the wiring and dont forget to remove the engine bay temp sensor and hand brake etc
Put the gear selector to one side you will have enough space to work and remove the centre section.
https://goo.gl/photos/YkqzThncj42G7wBX8
Once that is out of the way all is revealed!!
Pipework
Locate the servo vac pipe, you can try a suck on here to to check for any leakage from the servo but it needs quite a lug so vacuum pump would be best but if you haven't got one then with the pipe attached clamp off the pipe start the engine and see if there is any improvement. If there is then you may have a leak at the servo or the pipework in between. Dont clamp this pipe if it is nylon. You will have to suck.
N.B likely if the servo is leaking you will notice a hard brake pedal this can be a clue.
https://goo.gl/photos/dz246dAhCLYfEFGu8
Now check all the induction hoses after the Air Flow Meter (AFM) the thing that sits on the top of the air filter
This one has a blue dot.
https://goo.gl/photos/GKCdAc8mdnkTfn2G9
Look for cracks and splits in the main ducting pay particular attention to underside of the duct at the point that it attaches to the engine throttle body at the back of the engine and the elbows (2) as they enter that duct.
https://goo.gl/photos/VxUyZwFnvc7CszrV7
On the 2.0Ltr the ISCV is at the front of the engine the pipework passes along the offside of the block and into a Y branch then onto the main induction duct at the rear.Check that area thoroughly especially where the elbows go into the main duct. You will need to look hard at all this pipework as the holes can be tiny.
See it?
If the elbows are damaged they can be replaced by 9mm nylon elbows like this.
https://goo.gl/photos/8csPTZjaDCtmBAzA8
Glue them into place using PU adhesive not silicon sealant.
Anything that allows uncontrolled air into the idle system is not good so you will need to replace any damaged or leaking pipe work before carrying on.
Last on the list for the time being is the Pollution Control Valve (PCV) this pushes into the front of the rocker cover.It is worth noting that problems here can lead to gaskets letting by like the rocker cover gasket!
Essentially its a one way valve.
Remove the valve and suck and blow it should allow air one way and not the other. If you have some carb cleaner or petrol it would be a good time to give that a bit of a flush out.
https://goo.gl/photos/2u3EDXNnyYSo3Hp9A
That should be all the idle circuit pipework covered.
I think?
Re assemble and check the running.
The next post deals with the ISCValve.
So here goes.....
Pipework
See it?
I think?
