MX5 clock fitting
MX5 clock fitting
I've got hold of the MX5 clock/cubby combination. It has been supplied with the plug.
I just wondered if anyone could help with which wires to connect up to get it working.
I beieve I will only need a live and a negative but don't know if thats right or even which colours they might be.
It's too much to hope they are simply red and black.
Thanks in advance.
Thanks in advance.
JAL side conversion V6 Grey metallic
Re: MX5 clock fitting
Thank you. Yes, this does half the job for me. Now I need to identify which are the equivalent wires on my bongo. I'm afraid I have no electrical skills at all and I wouldn't know how to use an electrical tester even if I had one. I'm hoping I can identify them by coulour at some point.Northern Bongolow wrote:does this sort of thing help any.
http://mazdamenders.net/~mazdamen/forum ... php?t=2801
Thanks for the reply. Very helpful as a start.
TheNewRooster
- Junior Bongonaut
The wiring on the stereo plug where you can take feeds from (soldered) are :
BLUE / RED +ve PERMANENT
BLUE +ve IGNITION
RED / BLACK ILLUMINATION
BLACK (thin) NEGATIVE
BLACK / RED (heavy) NEGATIVE
BLUE +ve IGNITION
I'm Back.... A little older, wiser and a lot calmer.
And that completes the circuit I do believe.TheNewRooster wrote:The wiring on the stereo plug where you can take feeds from (soldered) are :
BLUE +ve IGNITION
Many thanks..
TheNewRooster
- Junior Bongonaut
Many thanks..![]()
Welcome back dude - great to have you back on hereTheNewRooster wrote:The wiring on the stereo plug where you can take feeds from (soldered) are :
BLUE +ve IGNITION
- haydn callow
Good to have you back Rooster!!!!!
TheNewRooster
- Junior Bongonaut
TheNewRooster
- Junior Bongonaut
Thanks Haydnhaydn callow wrote:Good to have you back Rooster!!!!!
