Central locking
Posted: Mon Jan 30, 2017 4:44 pm
by Dudleian
'97 AFT, 2.5tdi, 2-wheel drive.
Why does the central locking only work off the driver's door? Is it because
A - it's supposed to?..
B - something's bust?
C - the Cobra 4100 alarm/immobiliser is confusing the c/l system?
D - a combination of the above?
E - would I be better off disconnecting the Cobra from the c/l altogether (assuming I can figure out how to do it) and replace the c/l system
I'm unsure where to start first so any advice would be helpful
Re: Central locking
Posted: Mon Jan 30, 2017 5:35 pm
My 95 model Bongo has only ever central locked from drivers door, if that helps.
Re: Central locking
Posted: Mon Jan 30, 2017 6:04 pm
Answer - A
Its actually an option, the switch that operates the relay to release the other doors is driven from the lock itself.
If you want a remote fob, then you add a single motor to the door lock and the remote operates that alone, which then operates the switch for the other doors.
Re: Central locking
Posted: Wed Feb 01, 2017 10:19 am
by Dudleian
Thanks Geoff - I've read that the Cobra is not always fully compatible with remote central locking and that certainly seems to be the case with mine (every now and then the fob will unlock the driver's door as it disarms the immobiliser and on vert rare occasions it will unlock everything) I'm not too fussed about remote locking but it would be nice to unlock everything from any chosen lock
Re: Central locking
Posted: Thu Feb 02, 2017 2:33 pm
by NathM
Dudleian wrote:'97 AFT, 2.5tdi, 2-wheel drive.
A- Its single point locking so is only controlled from the drivers door
B- No
C- Connecting directly into the CDL system is a major pain in the backside, so a separate contol motor/actuator is usually used.
D - You might find you dont have an actuator fitted to allow the alarm to control it.
E- you'll need to investigate further, Ive seen lots of lazy installers who dont bother to fit an actuator, they also dont bother to connect the boot and or sliding door into the perimeter protection.
Cobra locking will be on an Orange and a Purple wire, configuration via an Orange (and)Purple wire and yellow/Black trace, grey/black trace. Do you have extra wires running between the door and Pillar?
