Spare wheel removal
Posted: Fri Oct 28, 2016 8:12 am
by callum
Hi folks,
I have a full size wheel to replace the space saver, can you remove the spare without the long rod that i see on ebay? I have the flatter handle looking part, but not the rod.
Any help appreciated. I shall buy a rod if not, but would rather not!
Re: Spare wheel removal
Posted: Fri Oct 28, 2016 8:45 am
by dnitu001
Hello callum
Don't think you can.
As the rod is guided to a cable winding winch.
It is a very simple design
Given the considerable skills creativity and craftsmanship you have shown
Would imagine you can create something
Important elements
Diameter of the rod. To fit though the bumper hole
Length to reach the mechanism
Then the flat part at the end.
Which given you have acsess to a cutter and a welder you can make it yourself.
Pm me and I will be happy to pictures of mine against a tape measure to allow you to fabricate one.
Seems little you don't seem to be able to make
Best wishes for all your future endevor
David
Posted: Fri Oct 28, 2016 9:15 am
by Bob
Agree with David.
You could drill through one end of some round bar and put a pin through to fit the winch end then weld a nut on the other end so you coukd turn it with a socket/rachet or the wheel brace.
Don't over tighten when winding up or you can deform the floor.
Posted: Fri Oct 28, 2016 10:32 am
Posted: Fri Oct 28, 2016 2:22 pm
by Jillygumbo
Perhaps you could borrow one?
Posted: Fri Oct 28, 2016 8:01 pm
by Bob
And the breakers often have them, BUT - have you checked the 'roof' of the side door cubby?
They're often clipped up there.
Posted: Sat Oct 29, 2016 4:50 pm
by callum
Oi, Bob, i owe you a beer!
Who'd have thunk it, given how much of the van i have dissected, that i never noticed it in it's intended position!
And folks, that is why this forum is only equalled by the MMOC for most useful members. Will be sad to not be here soon.
Thanks for the kind words before Bob suggested the obvious, i'm clearly not that great! Ha!
Posted: Sat Oct 29, 2016 5:06 pm
by Bob
Hey ho, a few have been caught by that one.
Glad to help, and that's why its always worth asking.
Posted: Sun Oct 30, 2016 9:21 pm
by callum
Changed the wheel today, what a fantastic system that is! Mental Mazda!
Posted: Sun Oct 30, 2016 11:02 pm
Word of warning DON'T wind up the cable without a wheel being in place, the loose cable can overlap itself and tangle making it impossible to lower without removing the entire mechanism .... If you put the replaced wheel in the van, then just tie up the extended cable under the rear bumper!
Posted: Mon Oct 31, 2016 8:08 am
by callum
Sounds like you may have experienced this!
Luckily i put the "new" wheel straight under there, so didn't have the misfortune of what you describe.
Why did Mazda not fit a full size spare if there is space for it? You'd think the cost of producing the space saver is greater than producing an extra full size steel wheel.
