handbrake assembly
Posted: Fri Oct 20, 2006 7:31 pm
help please,
after removing the wire for my alarm on the handbrake sensor the little spring flew off and i cant figure how it goes back together correctly.
would someone please remove their console and take a close up photo so i can put mine together correctly.
currently i cant use the handbrake and the warning light shows all the time because the little wire is constant contact with the metal chassis.
or if no photo a discription of how the parts fit together in the correct order.
theres only 4 parts but at 1.45 this morning i was too tired to continue with it.
2 hours to fit a replacement turbo and 5 hours to stop it smoking and then rebuild it all again.
cheers cause this is all ive got left to build.
