Wheel arch spats/covers
Posted: Mon Sep 19, 2016 2:37 pm
by Bongolia
Anyone here got any recommendations as to the best or worst wheel arch spats?
Seen these on fleabay
http://www.ebay.co.uk/itm/MAZDA-BONGO-F ... SwBLlU~piw
anyone got them?
Re: Wheel arch spats/covers
Posted: Mon Sep 19, 2016 2:44 pm
Seem to recall you have to watch out with some trims that the n/s/r one doesn't foul the sliding door when opening it. Daresay these ones don't if listed as for Bongo but maybe check with the vendor?
Posted: Mon Sep 19, 2016 3:04 pm
by Bongolia
Good point Mike. something I hadn't considered.
Posted: Mon Sep 19, 2016 3:52 pm
by windywatson
Hi, just fitted the stainless steel/chrome ones you can get from E-bay. Cleaned up & treated the rust on my rear arches but struggled to get the paint work to look good. So the s/s arch trims were just the ticket to mask the DIY paint job until I can afford a re-spray.
Vanx are currently doing their ones for the bongo on offer at a good price & they are copies of MAZDA's own so should be an excellent fit. The only drawback with the E-bay stainless/chrome ones is the fastening method leave a little to be desired, but it does the job.
Posted: Mon Sep 19, 2016 8:21 pm
by Bongolia
Thanks for that Windy. Were they the same as in the link in my OP?
And you did fit four?
If yes would the fronts fit a facelift model?
Ta.
Posted: Mon Sep 19, 2016 8:54 pm
by windywatson
Yeh same as the e-bay link you posted.
I have 2 Bongos pre & post face lift. I have offered them up to both & they will fit both. My face lift has the body kit with the side skirtes. The front spats require the fixings that hold the side skirt to bottom of the front wheel arch removing to allow the bottom of the spat to be tucked betweem the arch and skirt. As the spat is only 1mm stainless steel sheet it sandwitches in between ok. There is also one other thing to look out for. As the sheet is stamped out there is a very sharp edge on the inside of the lip that tucks under the arch. This needs to be filed to remove as I found that it is sharp enough to scrape the paint off down to the undercoat.
Posted: Mon Sep 19, 2016 10:45 pm
by Bongolia
Brilliant mate thanks. I intend to fit them to an Aero so that was very helpful. Ta.
Posted: Mon Sep 19, 2016 10:48 pm
by Bongolia
Ordered
