Page 1 of 2
Last few jobs
Posted: Wed Sep 14, 2016 4:38 pm
by Scratch
Very happy with my 2L petrol Bongo, just passed it's second MOT with no issues. I have decided to stay unconverted as that suits us although I have taken the rear seats out at the moment for camping during the summer. I have a few small jobs that I need fixing and am looking to see how others have achieved this. I am not a DIY expert and would like to get somebody to do these. Do you think a good body shop / garage could do these?
Replace the dangly rear fog light - this is just getting on my nerves now.
Fix the temperature gauge. A couple of people have tried but it's still not working. I think it must need a new thermostat.
Replace the Japanese radio. I have chosen the Pioneer model I want but it will need connecting to the leisure battery and rear view camera.
Any advice , as always, welcome.
Re: Last few jobs
Posted: Wed Sep 14, 2016 4:52 pm
Most garages should be able to do that, its a common thing.
No not a Thermostat, that controls the flow of the coolant around the system, its most likely that the connection to or the sensor itself that monitors the engine temperature to display on the gauge see here for the 2l its part 18-510;
May not be possible to connect the camera, if its an original Japanese one then the plug is not compatible with modern systems and the display in the Pioneer may not display the same version of NTSC (each country has its own variations).
The normal method to connect the radio is to use an ISO plug adaptor from Mazda to the ISO standard, which most 3rd party radios use. Which adaptor depends on the year of the vehicle.
Re: Last few jobs
Posted: Wed Sep 14, 2016 4:56 pm
by Bob
Fog light, pretty much anyone can do, easy.
Temp gauge, what is the problem, not moving at all/going up and down? Why do you think thermostat?
Radio, again easy enough but may not work with Japaneese reversing camera. For the amount of power a radio uses I wouldn't worry about plumbing it to the LB, but its not difficult.
Hope that helps a little.
Re: Last few jobs
Posted: Wed Sep 14, 2016 10:27 pm
by Scratch
Thanks for the replies. I'll get the foglight and radio sorted then. The temperature gauge doesn't move (stuck at lowest level) unless in very slow traffic for a long time. It then moves to a central position but drops down as soon as you get moving again. I have had it checked by a Bongo friendly garage a couple of times and the sensor has been changed but still no luck. Theonly thing they could then suggest was a new thermostat.
Re: Last few jobs
Posted: Wed Sep 14, 2016 10:30 pm
Ah the gauge works then !
Yes the thermostat, sounds like it has been removed often due to "problems" and its a quick cure
Re: Last few jobs
Posted: Thu Sep 15, 2016 4:51 pm
by Scratch
Thanks for that. Now it's been confirmed that it looks like I need a new thermostat I'll get it sorted
Re: Last few jobs
Posted: Tue Oct 25, 2016 9:37 am
by Scratch
Pioneer stereo fitted. Installer tried but couldn't connect to factory fitted rear view camera.
Very please with DAB radio/CD/DVD/Bluetooth/IPhone/IPod etc. All work well. Small screen mounted aerial reception is great so needn't have worried.
Connected to starter rather that leisure battery but presume that this will be fine when watching a DVD in bed!
Re: Last few jobs
Posted: Tue Oct 25, 2016 11:23 am
by Bob
Sounds good.
Re: Last few jobs
Posted: Thu Oct 27, 2016 2:12 pm
by Jimbobvfr400
You've got a few options for the fog. You could get a hole cut in the bumper and mount one flush there, you could sacrifice a reverse light on the OSR and true it into a fog with a red bulb or when I got mine there was a small LED light mounted in the reflector at the bottom of my new style rear lights, search eBay for eagle eye LED marker lights.
Re: Last few jobs
Posted: Thu Oct 27, 2016 11:56 pm
by cmm303
Scratch wrote:Thanks for the replies. I'll get the foglight and radio sorted then. The temperature gauge doesn't move (stuck at lowest level) unless in very slow traffic for a long time. It then moves to a central position but drops down as soon as you get moving again. I have had it checked by a Bongo friendly garage a couple of times and the sensor has been changed but still no luck. Theonly thing they could then suggest was a new thermostat.
do you mean it doesn't rise off COLD? The fact it responds to small increases and decreases in temp makes me wonder if it is a modified gauge. If it rises to a couple of mm above cold when warm it could be a modified with 110 ohm which under load can easily indicate up to 12 or 1 o'clock
Re: Last few jobs
Posted: Fri Oct 28, 2016 9:50 am
by Scratch
No it stays on cold with no movement all the time unless I am crawling along for a period of time. It then rises but as soon as I start moving again drops back to cold.
Re: Last few jobs
Posted: Fri Oct 28, 2016 9:59 am
Scratch wrote:No it stays on cold with no movement all the time unless I am crawling along for a period of time. It then rises but as soon as I start moving again drops back to cold.
Sounds like classic symptoms of a thermostat stuck open to me. I've diagnosed two of my previous cars similarly and a new thermostat fixed it.
Re: Last few jobs
Posted: Thu Dec 22, 2016 11:09 am
by Scratch
I finally got the new thermostat fitted and the temperature gauge now works along with the heater (which I didn't realise wasn't working until it got cold)
Re: Last few jobs
Posted: Thu Dec 22, 2016 1:06 pm
Scratch wrote:I finally got the new thermostat fitted and the temperature gauge now works along with the heater (which I didn't realise wasn't working until it got cold)
Good job well done. Enjoy
Re: Last few jobs
Posted: Thu Dec 22, 2016 8:10 pm
by Bob
Yep, well done.
