Fuel gauge
Posted: Wed Sep 07, 2016 10:32 am
Hi folks,
I assume i havethe classic earthing issue of the fuel gauge. It appears to be stuck at just under half a tank, i put £50 of diesel in it, so it should've gone higher.
I noticed the other day that it had stayed at empty after filling up with £20, then it jumped up to the normal position where it should be.
Couple of questions, is the gauge likely to drop as normal once the fuel is lower than "just lower than half" that the gauge is at or should i be more cautious and fill it up?
Is it possible to do the extra earth from underneath? My conversion is on top and i really don't want to rip it all out just for easier access.
Many thanks in advance!
