rear heater unit + upper brake light
Posted: Thu Aug 11, 2016 1:26 pm
by Sidb
Is it possible to take the rear heater unit out as it will never be used when my new side units go in also it would be less pipe work to look after.
I have tested the led lights they are ok
checked about 12 inches of cable that comes through the rear of roof no breaks any ideas.
the back light cluster brake lights work fine.
Re: rear heater unit + upper brake light
Posted: Thu Aug 11, 2016 8:45 pm
by cmm303
Sidb wrote:Is it possible to take the rear heater unit out as it will never be used when my new side units go in also it would be less pipe work to look after.
Yes. This thread may help.
http://igmaynard.co.uk/bongo/forum/view ... ss#p636467
Posted: Fri Aug 26, 2016 12:00 pm
by Sidb
Thanks CMM303 for the thread on removing rear heater unit it worked a treat unit now out air con pipes welded and tested water pipes fitted with blanking kit thank you very much.
Posted: Tue Aug 30, 2016 12:36 pm
by cmm303
Sidb wrote:Thanks CMM303 for the thread on removing rear heater unit it worked a treat unit now out air con pipes welded and tested water pipes fitted with blanking kit thank you very much.
=D> =D> =D> . Excellent stuff.
