				Front wheel alingment settings
				Posted: Thu Jun 09, 2016 6:55 pm
				by nth
				Im after the front wheel alingment toe settings for a 95 4WD model if anyone has them.
				Re: Front wheel alingment settings
				Posted: Thu Jun 09, 2016 8:46 pm
				by Northern Bongolow
				most including me set them to straight. same tyres on my for wheel drive for 6 years.
				Posted: Thu Jun 09, 2016 9:15 pm
				by rita
				Northern Bongolow wrote:most including me set them to straight. same tyres on my for wheel drive for 6 years.
THAT MADE ME chuckle, the correct alignment for this vehicle IS 1~7 mm Toe IN. And that is Straight from the straight horses mouth.
				Posted: Fri Jun 10, 2016 10:12 pm
				im glad  1mm can cheer you up.
				Posted: Sat Jun 11, 2016 9:17 am
				by rita
				Northern Bongolow wrote:im glad  1mm can cheer you up.
No comment, just you keeping  yourself straight makes me very happy.
PS its actually 1 to
7mm Toe In.
				Posted: Tue Feb 21, 2017 11:22 am
				by petejleonard
				rita wrote:Northern Bongolow wrote:im glad  1mm can cheer you up.
7mm Toe In.
Hi, is this for all Bongos?
I have an '05 2.0L Petrol.
I haven't had it long, but I suspect tracking may be slightly off as the wheel vibrates slightly at around 60mph and it pulls to the left (though the side conversion probably doesn't help).
I am also getting quite poor mpg at the moment, so trying to check all things out that can help.
				Posted: Tue Feb 21, 2017 1:07 pm
				by Bongolia
				Steering vibration will be wheel balance and tracking would not cause any pull unless it was miles out.
Make sure tyre pressures are equal and they are the same size per axle  if all good  then swop the fronts round as tyre bias is normally the cause of slight pulls especially if they are different makes.
If that fails the maybe drop it into your friendly local garage and get them to check it over.
				Posted: Tue Feb 21, 2017 1:11 pm
				by petejleonard
				Ah, that's helpful. Thanks
				Posted: Tue Feb 21, 2017 8:07 pm
				by rita
				It might also be worthwhile checking that the steering rack is secure.
Fav wheel balance or dodgy tyre.
Good Luck
