Rear 12v socket
Posted: Fri Apr 22, 2016 5:46 pm
by mycallsevern
I have an early Freda and my rear 12v socket isn't working. Are there any common issues with these? It looks a bit rusty inside so is it best to start by replacing the socket and see if that works? Or is there a fuse I should be checking? If I am to replace the socket where do I get this from?
All other electrics are working as normal and the van is standard (no leisure battery or hookup).
Thanks for your help, Michael
Re: Rear 12v socket
Posted: Fri Apr 22, 2016 7:59 pm
by philpdr
There should be a fuse link on the bottom of the socket itself,if that's intact and you've got power there it could just need cleaning up with contact cleaner.I'm not sure if the sockets are a universal size but most accessory shops sell them.
Re: Rear 12v socket
Posted: Fri Jul 08, 2016 5:17 pm
by mycallsevern
Thanks, I removed the socket and tested the connection, wires were live so I just whacked a new socket in. Everything is working well now :D
