To reverse the rear seats or not....?
Posted: Mon Apr 18, 2016 3:13 pm
by HazelM
Hi!
Am a Bongo owner of 4 years, have two dogs who travel on the rear seats secured in via harnesses + I pull the seats forward so there is minimum space between rear and front seats & all has been good. However, I feel that reversing the rear seats will give us more room BUT I wonder how my dogs will cope with travelling backwards???? Anyone done this/had experience and how did it work out? PS My dogs are not used to crates (both at home & travelling) so would prefer not to introduce these.
Also....I set up the seats for sleeping & have read 'somewhere' that reversing the creates a gap of approx 6" between front & rear when lowered...is this the case? Hmmm...!!!!
I would be grateful for your comments.
Bongo & out! 3H's (Hazel, Herman & Hanz)
Re: To reverse the rear seats or not....?
Posted: Mon Apr 18, 2016 4:25 pm
by Bob
When we had estate cars our dogs sat in the back and seemed to face whichever way suited them, can't see it being a problem if you don't tell them.
Do you have the long rails and rear bench or short rails and flip up seats? This will make a difference to the gap.
Posted: Mon Apr 18, 2016 10:41 pm
by Bongoplod
My middle seats are reversed Hazel,Charlie travels on that,no problems.
My rear seat butts right up to the middle one,no gap
Dont forget that little lever under the seats to nudge them that extra bit
Brian
Posted: Tue Apr 19, 2016 12:03 pm
by Dr Fingers
Do you have the long rails and rear bench or short rails and flip up seats? This will make a difference to the gap.[/quote]
Which way does this go? Do short rails/flip up rears have the gap, or long rails/rear bench? Have removed our mids (short rails/flip up rears) but was considering reinstating the mids, reversed and rear facing.
Derek
Posted: Wed Apr 20, 2016 8:09 am
by HazelM
Hi and 'many thanks' for responding.
Am a bit confused over long or short rails....so.... as I look into the Bongo from the rear on the r/h side there is a long rail that runs from behind the drivers seat to the back and on the l/h side it is similar but shorter as that side has the sink etc. Am I correct in thinking that these are 'long rails'? The rear seats flip down.
Thanks for the info on dogs travelling backwards
(thinking about it perhaps a silly question) and yes, thank you Brian...it took me a while to suss out the lever to close the gap but now
. I gather the same will apply if the seats are reversed?
I have been considering investing in one of these swivel seats (passenger) but reversing the rear seats may well give me extra room and at no cost.
Thanks again, 3H's
Posted: Wed Apr 20, 2016 9:30 am
by Bob
Having flip up rear seats means you will have the short rails unless someone has done a mod.
Long ones can be fitted and there's a 'Fact Sheet' on how to modify them so the middle seat can be fitted either way and still lock.
Having a conversion this may not be worth the hassle, though.
Posted: Thu Apr 21, 2016 12:30 pm
by HazelM
Thanks Bob. Will have a look at the 'Fact Sheet'. I have two sons (hopefully 'strong' as I understand the rear seat is heavy) who can have a look with me & between us we will suss out. Again, many thanks.
3H's
