Ignition switched live supply
weebrian
Post by weebrian » Wed Dec 30, 2015 1:28 pm
Before I strip out the cab courtesy lights, can anyone tell me whether there is a switched live to the lighting cluster? I just need a feed for my traffic cam and this seems an obvious place if there is a supply there.
Re: Ignition switched live supply
Post by Bob » Wed Dec 30, 2015 2:04 pm
I would have thought the supply to the cab light was live, not switched.
I just ran the wire around the windscreen trim, down the A pillar and behind the binacle. Can't quite remember where I wired it in but you can now get 'Piggy Back' fuse holders.
cmm303
Post by cmm303 » Wed Dec 30, 2015 2:08 pm
Which cluster, cab lights? They run off an unswitched supply (Fuse 1, top left by knee). http://www.g8dhe.net/bwm/bwmanualp.htm?1995/Page_102
I have used a feed from either fuse 9 or 10 for a switched feed.
Chris with BertieB
weebrian
Post by weebrian » Wed Dec 30, 2015 2:43 pm
Thanks for the advice guys, i must admit that when I think about it, why would there be a switched supply.
Seasons greetings and all the best for 2016.
Darkstar
Post by Darkstar » Wed Dec 30, 2015 11:28 pm
My dash cam has a switched live and a permentant live and neutral. With my unit, because it switches off when the battery gets to a certain level to prevent battery drain, it uses the switched live to turn the unit back on when the engine is started.
Got a Bongo for the Wife, Best trade-in ever
the1andonly
Post by the1andonly » Fri Jan 01, 2016 8:20 pm
Piggy back fuses in action rhs switched live
