Bongo lights going on spontaneously.
Posted: Sun Dec 06, 2015 7:46 pm
Before I set about tracing out the wiring, I thought I would just ask if any one else came across this bongo fault.
Noticed one evening that the bongo head lights were on when I hadn't used it that day. Sure enough, the headlight switch was off. As it was not a convenient time to start repairs, I just pulled the lighting fuse, intending to sort it later in daylight. Half an hour later my wife noticed the head lights were on again. (Both times only the headlights, not rear or side).
So then I disconnected the batteries to prevent them going flat, and to investigate at a later date.
Just in case it might save me some time, has anyone else come across this? Or maybe have some experience of bongo wiring that might give them a clue. I obviously will need to start with the headlights relay, if I can find which one it is, and then try and find out what is feeding it independent of switch and fuse. If anyone can tell me where to find the relay, it would be a good start. I work as an electrical engineer, so am fairly clued up in a general way, just not had much bongo specific experience.
